File Inject from dashboard
Hello All
I have installed the node red contrib browser utils, albeit i manage to inject a file, i dont know ho to within the dashboard
Thank you in advance
JLG
Do you want to display the file you have uploaded in Node-RED in the dashboard
or do you want to choose a file and upload it using the dashboard?
Hello UKmoose
I would like to chose a file and upload it using the dashboard
Thank you
JLG
You can't do that using the node you mention. That is for loading a file into Node-RED when you are on the normal Node-RED canvas.
Where is the file you want to load? Is it on the machine running the Node-RED instance or on the machine where you are using the browser?
There are several examples on flows.nodered.org you could try that mention uploading files https://flows.nodered.org/?term=upload&num_pages=1
it´s on the machine where I am using the browser!!
I will take a look at the links
@ukmoose
I know that node I mentioned,d is only from canvas, I just would kike to that from dashboard, and the file is in the computer i would be running the dashboard
JLG
