File Name troubles
i have a data collector (DS18B20), collect 200 samples and write the data in a .csv file. The filename is composed from date and time, resulting in filenames like '2024-11-30 18:17.csv'
This is how i can read it in the directory on the raspi.
To have external access to the file i installed samba, added a user and configured the smb.conf.
The folder is available now on other PC's. (Windows ans Mint)
The problem is, the filename looks like W2VCD0~.csv.
The write file node allows several options like utf8, standard etc. I tried some of them, did not change anything.
Any ideas?
Thank you in advance.
Hi @alexander77 - as with all queries like this. - please provide us a flow export that is creating the files, we might be able to see something.
Shure.
Date and time are generated with the simpletime node.
var datum = msg.myymd;
var zeit = msg.mytime;
msg.filename reads as follows:
filename: "/home/raspi/public/2024-11-30 21:24.csv"
var howmany = msg.payload;
var out = "";
var time = flow.get("time");    // das ist die liste
var zeit = flow.get("zeit");
var date = flow.get("date");    // das ist die liste
var datum = flow.get("datum");  // das ist die aktuelle zeit
var sensor1 = flow.get("sensor1");
var sensor2 = flow.get("sensor2");
var sensor3 = flow.get("sensor3");
var sensor4 = flow.get("sensor4");
var sensor5 = flow.get("sensor5");
var sensor6 = flow.get("sensor6");
var sensor7 = flow.get("sensor7");
var sensor8 = flow.get("sensor8");
var sensor9 = flow.get("sensor9");
var sensor10 = flow.get("sensor10");
var sensor11 = flow.get("sensor11");
var index = 1;
out = "Datum;Zeit;Sensor1;Sensor2;Sensor3;Sensor4;Sensor5;Sensor6;Sensor7;Sensor8;Sensor9;Sensor10;Sensor11"+ "\x0d\x0a";
msg.filename = "/home/raspi/public/" + datum + " " + zeit + ".csv";
while (index < howmany) {
    out = out + date[index] + ";" + time[index] + ";" + sensor1[index] + " ; " + sensor2[index] + " ; " + sensor3[index] + ";" + sensor4[index] + ";" + sensor5[index] + ";" + sensor6[index] + ";" + sensor7[index] + ";" + sensor8[index] + ";" + sensor9[index] + ";" + sensor10[index] + ";" + sensor11[index] + "\x0d\x0a";
    index +=1;
msg.payload = out;
You know windows doesn't have : support in file names?
and if using samba - might be some odd behaviour happening
May I suggest simplifying it - with a change node to set the filename?
(changing the timezone to suite of course)
[{"id":"3a86f84d81ec95fd","type":"change","z":"2d7bf6e3.84c97a","name":"","rules":[{"t":"set","p":"filename","pt":"msg","to":"$moment().tz('Europe/London').format('DD.MM.YYYY-HH.mm') & '.csv'","tot":"jsonata"}],"action":"","property":"","from":"","to":"","reg":false,"x":370,"y":640,"wires":[["2c78e4eb788fde4a"]]},{"id":"e3bfc6ee29ee332b","type":"inject","z":"2d7bf6e3.84c97a","name":"","props":[{"p":"payload"},{"p":"topic","vt":"str"}],"repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"","payload":"","payloadType":"date","x":160,"y":700,"wires":[["3a86f84d81ec95fd"]]},{"id":"2c78e4eb788fde4a","type":"debug","z":"2d7bf6e3.84c97a","name":"debug 386","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"true","targetType":"full","statusVal":"","statusType":"auto","x":630,"y":680,"wires":[]}]
Get rid of spaces in the filenames too.
I suggest 202411302124.csv but make sure everything is zero filled to two places
@alexander77 like this in the change node
$moment().tz('Europe/London').format('YYYYMMDDHHmm') & '.csv'
Six characters followed by a tilda is for compatibility with old old systems.
From a post on superuser.com (12 years ago but it might still be relevant!)
It's a file name mangling problem. Samba is converting filenames down to old style DOS 8.3 filenames.
Edit /etc/smb.conf (*) and add mangled names=no to the [global] section and restart the smb service.
the way marcus-f-davies suggested works. Will try the entry in smb.conf as well.
Many Thanks, fellows!
