Hello good afternoon, I tell you what I want to do, filter a database by temperature and date, currently I show all the data in a table, but I want to filter it, I know what sentence using a sentence like: "select * from 'database' where 'temperature = 15', it will be filtered, but what I'm looking for is that I don't write the filter temperature, if I don't give it to a variable for example, thank you very much, I attach my flow.
Of course I can do that, but what I want to do is that in a date node or tex input node, enter date or date data and filter dynamically, all those filters do it from the UI
Well you could build the sql statement using switch nodes to decide if you want date, temperature or both ad then use a template node to build the statement.
You will have to decide what the conditions re that you will use. I'd suggest using the ui-form node to enter the date and/or temperature they both would be in the msg and you could then create your select statement based on which item(s) are filled in.
