I have a brand new install on Fedora, using the beginner install script (https://github.com/node-red/linux-installers) and none of the dropdown menus are viewable. I can 'select' them and use the arrow keys to sort-of tab through the hidden options, but a dropdown menu showing the complete contents does not work.
System:
Fedora 31
Firefox 70.0.1
NR: 1.0.3
Steps to reproduce:
Install on fresh F31 image, using script from rpm installers repo
open localhost:1880
attempt to use dropdown for 'repeat' in Inject node.
Interestingly, dropdowns for 'payload' work fine (and others with grey background).
Hi @dcsouthwick
That is very odd - the repeat element in the Inject node is a completely standard HTML <select> element with no custom code running against it (unlike the payload drop-downs which are custom elements).
Are there any error messages in the browser console?
Another bit of info I found for devs while trying to make a screencast of this problem.
It seems triggered when there is more than one monitor.
Doublescreen webcast (scroll right for 2nd screen and demo of broken dropdowns)
https://webm.red/EIKi
same actions, with one monitor disabled:
https://webm.red/w0p4
This actually seems to be some sort of bug
I'd suggest a bug with Firefox then - the rendering and interaction of those elements is provided by the browser and nothing to do with the node-red editor code.
Can you try a different browser to see if that's the case?
Yes, just installed chromium, and html renders as expected. Weird.
