Can you update again? You should be getting node-red-flexdash 0.4.154 and then node-red-vue 0.1.15 as a dependency.
Thanks for flagging this!!
All good now, thanks for the quick response ![]()
We'd prefer if you followed our naming guidelines and didn't publish modules with the node-red- prefix that didn't make clear they are a contrib package. Particularly if you're going to go with such a generic name like that.
Oh, I had forgotten the specifics, I'll add a scope with the next release...
@tve I realise how valuable log entries are, especially in the early stages of a node's development, but as flexdash moves from alpha to beta, could you kindly consider cutting down the logging to the node-RED log, as it produces pages of information at start-up, making it difficult to spot other non-flexdash error/issue log entries.
We had a similar situation with node-red-contrib-google-smarthome and it was overcome by having a checkbox in the node config to enable/disable logging, which allows users to enable verbose logging if they had any issues, otherwise keep it disabled.
For consideration...
Man, I can't wait to get back to some of my Node-Red projects to have an opportunity to try out FlexDash.
I look forward to welcoming you to the club ![]()
I'm currently trying to get my greenhouse watering controls implemented with FlexDash, as well as polishing the Motus station software (world-wide bird migration tracking) which also use FlexDash...
Can't wait to work on FD itself again, time to add a last feature and then move on to a hopefully short beta and 1.0 release. I already have 1.1 planned, aka full rewrite, but fully compatible... ![]()
Makes total sense, thanks for bringing it up!
I didn't succeed using the custom widget as array. It works flawless without, but disapeares when defined as array.
"id": "62a03b0578e1991f",
"type": "tab",
"label": "Flow 1",
"disabled": false,
"info": "",
"env": []
"id": "9e00f73ed906e7a7",
"type": "inject",
"z": "62a03b0578e1991f",
"props": [
"p": "payload"
"p": "title",
"v": "SSROut",
"vt": "str"
"p": "label",
"v": "off",
"vt": "str"
"repeat": "",
"crontab": "",
"once": false,
"onceDelay": 0.1,
"topic": "",
"payload": "0",
"payloadType": "num",
"x": 200,
"y": 150,
"f5470e30cfff160e"
"id": "7ad6d551fcbeaf32",
"type": "inject",
"props": [
"p": "payload"
"repeat": "",
"crontab": "",
"once": false,
"onceDelay": 0.1,
"topic": "",
"payload": "1",
"x": 200,
"y": 195,
"c26a2c4778e7d07e"
"id": "48feeb03597e2f0c",
"type": "flexdash custom",
"name": "Led",
"title": "LED",
"sfc_source": "<template>\r\n <!-- For classes see the entire styles section of https://next.vuetifyjs.com/en/styles/border-radius/ -->\r\n <div class=\"flex-grow-1 w-100 pa-2 d-flex flex-row align-center justify-space-around\">\r\n <div>{{ label }}</div>\r\n <div :class=\"`led bg-${color}`\" />\r\n </div>\r\n</template>\r\n\r\n<style scoped>\r\n div.led {\r\n height: 80%;\r\n aspect-ratio: 1;\r\n width: min-content;\r\n border-radius: 50%;\r\n box-shadow: 0px 0px 15px 0px v-bind(color), rgba(0, 0, 0, 0.17) 0px -3px 2.5px 0px inset, rgba(0, 0, 0, 0.15) 0px -5px 4px 0px inset, rgba(0, 0, 0,\r\n 0.1) 0px -11px 5px 0px inset;\r\n }\r\n</style>\r\n\r\n<script>\r\n export default {\r\n props: {\r\n payload: { default: undefined }, // type is \"any\"\r\n label: { default: \"state\", type: String }\r\n },\r\n computed: {\r\n color() {\r\n // use any material-design color: https://vuetifyjs.com/en/styles/colors/#material-colors\r\n // (warning, it's link to the old docs 'cause that page is broken in the new ones...)\r\n if (this.payload == 0) return \"green\"\r\n else if (this.payload == null) return \"grey\" // null or undefined\r\n else return \"red\"\r\n }\r\n }\r\n}\r\n</script>",
"fd_container": "a96ede31d15e8fcc",
"fd_cols": 1,
"fd_rows": 1,
"fd_array": true,
"fd_array_max": 10,
"x": 525,
"y": 195,
"id": "17c70a1589f45f67",
"type": "inject",
"props": [
"p": "label",
"v": "sce",
"vt": "str"
"repeat": "",
"crontab": "",
"once": false,
"onceDelay": 0.1,
"topic": "",
"x": 200,
"y": 245,
"b5e12c1521237afa"
"id": "f5470e30cfff160e",
"type": "function",
"name": "makeArray",
"func": "msg.payload = [msg.payload, msg.payload];\nmsg.topic = [msg.topic, msg.topic + \"sce\"];\nreturn msg;",
"outputs": 1,
"noerr": 0,
"initialize": "",
"finalize": "",
"libs": [],
"x": 350,
"y": 150,
"48feeb03597e2f0c"
"id": "c26a2c4778e7d07e",
"type": "function",
"outputs": 1,
"noerr": 0,
"initialize": "",
"finalize": "",
"libs": [],
"x": 350,
"y": 195,
"48feeb03597e2f0c"
"id": "b5e12c1521237afa",
"type": "function",
"outputs": 1,
"noerr": 0,
"initialize": "",
"finalize": "",
"libs": [],
"x": 350,
"y": 245,
"48feeb03597e2f0c"
"id": "a96ede31d15e8fcc",
"type": "flexdash container",
"name": "Repro",
"title": "",
"kind": "StdGrid",
"fd_children": ",48feeb03597e2f0c",
"tab": "1e908252f3517797",
"min_cols": "6",
"max_cols": "20",
"unicast": "ignore",
"parent": "",
"solid": false,
"cols": "1",
"rows": "1"
"id": "1e908252f3517797",
"type": "flexdash tab",
"name": "Repros",
"icon": "mdi-view-dashboard",
"title": "Repro",
"fd_children": ",a96ede31d15e8fcc",
"fd": "26bf919f14de42c9"
What am I doing wrong? Claus
I wonder what I am doing wrong... ![]()
The dynamic loading stuff that the custom widget uses needs a full rewrite, now that I understand things better. I'll take a look, but it may not be practical to make custom widgets work in an array. TBD.
