FlexDash Socket.io
I'm having some issues with getting FlexDash setup with Socket.io. I have flexdash setup and install, the start.html file created and in flexdash-src directory and I'm receiving the below error.
Any ideas or additional info I can provide to help troubleshoot?
I'm relatively new to node-red but making quick progress.
@tve - Thorston, for info
@ryanprel I would recommend holding off on trying out FlexDash. I have a complete overhaul in the works that should be ready for initial testing in 1-2 weeks. It completely changes the way it integrates with Node-RED, so anything you do now will be obsolete.
WRT your problem at hand, the node-red log may have some errors, but also the browser's console. Unfortunately the websockets underlying socket.io don't provide decent error feedback. BTW, you have HTTPS checked: do you actually have Node-RED running with HTTPS?
@Paul-Reed thanks for the ping!
Thanks for the feedback on the issue - I'll just hold off on building that out and work on other stuff for now. I don't have https setup so good catch. Disabling https didn't make any difference for my setup. Since I don't have anything configured yet, would you recommend just removing all of FlexDash and install everything from scratch for your new update? @tve
Yes, removing it all is the best thing. Sorry for the delay and thanks for your interest!
Thanks for putting so much work into this!
Any update on the status of the FlexDash update?
It "might" be that Thorsten is waiting for me (already some weeks), because I promised him to help with some stuff. But unfortunately I have almost no free time at the moment. Familly life goes first...
I wish I could just point the finger at you, Bart, but I've been busy with another project and mostly just life. I have made progress. The docs have advanced quite a bit, the example flows are almost all there, I've tested all but the plot widgets in the process, and I've migrated by production NR to a new server running the V3 beta. Now I need to migrate my dashboard fully to FlexDash and see what else shakes out.
I still see a major race condition in the NR V3 UI that affects FD and I haven't tracked that down. Not that the previous race condition I hit has been fixed... (Race condition when loading module with both Plugin and Nodes · Issue #3523 · node-red/node-red · GitHub)
FYI: issue nodes get moved to current tab on flow-edit launch due to race condition · Issue #3699 · node-red/node-red · GitHub
