Flow context not being saved over NR restarts
I've got this in my settings.js
     /** Context Storage
      * The following property can be used to enable context storage. The configuration
      * provided here will enable file-based context that flushes to disk every 30 seconds.
      * Refer to the documentation for further options: https://nodered.org/docs/api/context/
     contextStorage: {
         default: {
             module:"localfilesystem"
but I'm losing the values of my flow context variables when I re-start NR
How do I go about debugging what the issue is?
NR running on Win11
How is Node-RED restarting? e.g. is it shutting down gracefully or failing due to a out of memory error or similar?
Also not the entry in the docs:
it caches the values in memory and only writes them out to the file-system every 30 seconds.
#PEBKAC issue
I hadn't edited the right settings.js file!
I think I need to go and have a lie-down :slight_smile:
