Flow to Mermaid Diagram
Hi
I found this amazing link.
Installed and tinkered with it - and works gives very good results.
Have asked the author - if this can be converted into a standard node.
It takes input as flow json (for a tab) and gives the diagram as output.
This combined with NR apis and NR Dashboard - can allow creating automatic Mermaid diagrams for user to visualize.
We can also create flow which will automatically update the info property for a flow and post it back - so that even in editor the diagram gets created automatically.
Any ides how can this be done - would be welcome .
Dashboard 2 already has built in support for mermaid diagrams.
Right. Hence i need a node which will convert flow to Mermaid diagram which then i can feed to ui-markdown.
