I have a flow context object called testobject:
test1:[{some content..}],
test2:[{some other content..}]
I want to use a change node to return the property that was requested via req.params.item
req.params.item = 'test1'
In jsonata, I would think the following:
$flowContext("testobject")[req.params.item]
but this does not return anything, what am I missing ?
I'm not a jsonata fan (or regular user of it) but I am not sure property access via square brackets is supported?
Try
$lookup($flowContext("testobject"), req.params.item)
Far easier in function node (as I am certain you know)
You might also be able to simply chose flow (instead of jsonata) and enter testobject[msg.req.params.item] in the field.
Interesting, I was not aware, very nice indeed. I was complicating things I see.
