Flowfuse Dashboard 2.0 issue: ERR_TOO_MANY_REDIRECTS
Hello, today I ran into the following issue with ui-builder after rebooting my Raspberry PI (on which node red is running on):
Whenever I try to open the website that is delivered through the ui-builder node I get the following error in the browser: ERR_TOO_MANY_REDIRECTS
When I inspect the process in the browser dev tools it keeps redirecting the page URL from http://noderedip:1880/uibuilderpage to http://noderedip:1880/uibuilderpage/ and back to http://noderedip:1880/uibuilderpage (with and without trailing slash) several times. Status code is always: 301 (moved permanently) for each attempt before it redirects.
What did I change?
Nothing really that I am aware of. The only thing that could have some impact is that NodeJS was updated through APT: nodejs/nodistro 20.19.2-1nodesource1 arm64 [from: 20.19.1-1nodesource1]. But I think this shouldn't be an issue.
What did I try already?
  • Open the page on different devices / in a private tab -> doesn't work
  • Open the page with and without trailing slash
  • Open the page directly without reverse proxy (noderedip:1880/uibuilderpage) -> doesn't work
  • Create a new ui-builder website using the blank template -> doesn't work
  • Open the page noderedip:1880/uibuilder -> works
  • Open the node-red Dashboard 2.0 noderedip:1880/dashboard -> works
  • Restarting node-red and the whole system several times -> still doesn't work
I'm slowly running out of ideas of what else I could try to track down the error. :thinking:
Hi, I need to pop out for something so just a quick reply.
This is almost always caused by a reverse proxy misconfiguration.
So you are using a proxy?
By default I would expect http://noderedip:1880/uibuilderpage to appear as http://noderedip:1880/uibuilderpage/ after entry since the real URL is actually http://*noderedip* :1880/uibuilderpage/index.html
ExpressJS is handling the fact that a trailing path translates to an index.html page.
Yes, normally I am using a reverse proxy that translates http://nodered.fritz.box to http://192.168.1.2:1880
To make sure the reverse proxy isn't the issue I did access the ui-builder website directly, using the IP+Port: http://192.168.1.2:1880/uibuilderpage
Now I just found out that that the following works: http://192.168.1.2:1880/uibuilderpage/index.html (this works as well: http://nodered.fritz.box/uibuilderpage/index.html).
Back for a bit.
http://192.168.1.2:1880/uibuilderpage should end up in your browser's address bar as http://192.168.1.2:1880/uibuilderpage/ with a standard configuration.
Yes, they both work because neither the proxy nor ExpressJS need to standardise the URL.
For me, both the proxied and none proxied routes translate from no trailing slash to a trailing slash.
In the network tab of your browser's dev tools, set it to "Preserve log" so that you can see any redirects. Then you should see something like this:
That is direct to port 1880 so no proxy.
And here we are via the proxy (note that I disabled the cache to see this properly):
If you include the trailing / then no redirect should be needed. So if you are sill seeing a redirect at that point, it isn't uibuilder doing it. Some setting in the proxy or some setting in Node-RED is doing it.
You could possibly try turning on UIBUILDER's custom ExpressJS server which you do by specifying a port in the uibuilder section of settings.js (see the docs).
Then you will know that the proxy isn't involved because it will be on a different port (unless you have some setting in your proxy to intercept everything).
What proxy are you using? I use NGINX.
Ah, have you told Node.js to trust the proxy? You can do that in node-red's settings.js
    /** The following property can be used to pass custom options to the Express.js
     * server used by Node-RED. For a full list of available options, refer
     * to http://expressjs.com/en/api.html#app.settings.table
    httpServerOptions: {
        // http://expressjs.com/en/api.html#trust.proxy.options.table
        'trust proxy': '127.0.0.1/8, ::1/128', // true,  // true/false; or subnet(s) to trust; or custom function returning true/false. default=false
        'x-powered-by': false,
or
    /** If you need to set an http proxy to reach out, please set an environment variable
     * called http_proxy (or HTTP_PROXY) outside of Node-RED in the operating system.
     * For example - http_proxy=http://myproxy.com:8080
     * (Setting it here will have no effect)
     * You may also specify no_proxy (or NO_PROXY) to supply a comma separated
     * list of domains to not proxy, eg - no_proxy=.acme.co,.acme.co.uk
For reference, here are my NGINX reverse proxy headers:
# Don't forget to also add proxy_pass url;
  proxy_set_header Forwarded "by=$host;for=$proxy_add_x_forwarded_for;host=$host;proto=$scheme";
  proxy_set_header Via       "$scheme/1.1 $host:$server_port";
  proxy_set_header Host              $host;
  proxy_set_header X-Forwarded-For   $proxy_add_x_forwarded_for;
  proxy_set_header X-Forwarded-Host  $host;
  proxy_set_header X-Forwarded-Port  $server_port;
  proxy_set_header X-Forwarded-Proto $scheme;
  proxy_set_header X-Original-URI    $request_uri;
  proxy_set_header X-Real-IP         $remote_addr;
  # Proxy timeouts
  proxy_connect_timeout       60s;
  proxy_send_timeout          60s;
  proxy_read_timeout          60s;
  # If proxied responses happening too slowly, try turning off the buffering
  #proxy_buffering off;
# Common headers for proxy of websockets
proxy_http_version          1.1;
proxy_set_header Upgrade    $http_upgrade;
proxy_set_header Connection "upgrade";
And this to proxy everything in Node-RED:
  # Reverse Proxy
  proxy_pass https://localhost:1880/; # <== CHANGE TO MATCH Node-RED's base URL
Can you also please confirm what versions of node-red and uibuilder you are using?
I tried opening the page through the reverse proxy (using nginx proxy manager which is running in a docker container on the same machine):
When I try opening the page without the reverse proxy:
And here when I try to open it without the reverse proxy with trailing slash already:
It keeps redirecting back and forth no matter if I add the trailing slash or not or use the proxy or not. It is really strange.
Tried that, it works:
Tried that as well, doesn't help.
I am using:
  • Node Red 4.0.9
  • UI builder 7.2.0
  • NodeJS 20.19.2-1nodesource1 arm64
  • 6.12.25+rpt-rpi-v8 #1 SMP PREEMPT Debian 1:6.12.25-1+rpt1 (2025-04-30) aarch64
That is indeed very strange. I've only ever seen this happen with a wrongly configured proxy.
Hmm, I guess you could try disabling the proxy temporarily - that would at least completely eliminate that as an issue.
Long-shot but you could also try an in-private browsing session to make sure it isn't a caching issue of some weird kind.
Even longer shot - are you using the uibuilder front-end router?
I'm afraid I have to go offline for a few hours now. I'll try and check back later.
I've disabled the nginx proxymanager docker container temporarily and tried to directly open the ui-builder page using the IP+1880 port in a private browser window again. Same issue.
I am not using the front-end router and when I create a new ui-builder site using the blank template I get the same strange behaviour.
I also tried something else: I enabled httpStaticRoot: '/static/' in the settings.js. When I then try to open http://192.168.1.2:1880/static or http://192.168.1.2:1880/static/ it results in the same error like it does with the ui-builder pages. This prooves that this problem has nothing to do with ui-builder. It then must be an issue with the built in ExpressJS server.
Next I did downgrade the NodeJS version to the previously used one: 20.19.1-1nodesource1. This also changed nothing.
To make sure it has nothing to do with the settings.js I retrieved a two-week-old version from a backup. Last reboot (before todays reboot) was 9 days ago. That means I am now definitely using a settings.js that was working before and thus can't be the issue. However it's still the same.
@TotallyInformation I would like to thank you for the great support, but especially for the development of ui-builder, which is a super brilliant extension for Node-Red!
I keep trying things but for now I'm a bit lost.
I'm currently using v22 and I use the nodesource debian repo to manage things. (I'm running Debian on an Intel PC laptop). That shouldn't have any impact either way.
Yes, all very strange. Next thing to try would be to set up a completely new instance of node-red using a different userDir. My Alternate installer repo may help, it isn't a complete solution but it does have all the components. That may help you understand whether it is something buried in the node-red settings.
Thanks for that, always good to hear that people like it. As always, a new version is under way - this time focused on better and more flexible handling of templates.
I found the problem: It's the new version of the flowfuse dashboard 2.0 v1.0.24!
I created a fresh docker container running nodered/node-red:4.0.9-22 in it. Then I installed only the uibuilder node and created a testpage with the minimal template -> everything works!
So that means there shouldn't be an issue with my devices or my network configuration.
Then I installed the Flowfuse Dashboard:
I added only a single button to initialize the Dashboard (besides the uibuilder testpage):
The dashboard is working as intended:
However from this point on uibuilder stops working:
Then I completely remove the Flowfuse Dashboard again and restart the docker container, uibuilder works again:
I don't think this has anything to do with my environment and should be easy to reproduce for everyone.
It probably has something to do with that commit:
Ahh - that would make sense - I saw something similar with my worldmap node a few days ago - was only on a single docker instance I had and thought it was cache related, and I didn't investigate fully - and I wasn't using ui-builder... but yes this could be same for me. Calling @joepavitt !?
Thanks for pulling me in Dave, sorry for causing the problems from Dashboard. We should be scoping our check to Dashboard routes only.
I'll make sure this is fixed as a priority item given its impscy on other projects
Issue Opened: Redirect Loop for 3rd Party Projects · Issue #1708 · FlowFuse/node-red-dashboard · GitHub
The whole company at FlowFuse is at an onsite company summit this week, but will try and get a fix in. Alternatively, any JS devs reading this, please do feel free to open a PR!
If anyone needs instructions on how to downgrade d2, speak up and I'll post something.
Well done for working through it and finding the answer!
Seems unfortunate that this makes D2 behave differently from the default.
I just double-checked the standards and current SEO recommendations and all say that it doesn't matter whether you have trailing slashes or not, only that a site is consistent. Also the use of trailing slashes does not affect SEO as long as any canonical links match up.
Hmm, it seems that ExpressJS behaviour is actually inconsistent. In some cases the URL is redirected and in other cases it is not. From what I can tell (without testing), it appears to be something to do with Express's Route class.
Was the initial request to remove the trailing /, the fix for this then caused the new issues
