Worldmap Dashboard 2.0 iFrame example - error too many redirects
Hi forum,
I am learning to use @flowfuse/node-red-dashboard.
I tried following these two tutorials:
but always hit the same problem, i.e when I load http://localhost:1880/dashboard/worldmap the browser would not display the map and instead displayed "too many redirects". And I see this in the log:
18 May 22:06:18 - [info] [ui-base:Dashboard] Disconnected DsCeiEivjeDI5LcGAAAD due to transport close
If I removed all dashboard nodes including the config nodes, redeploy the flow and load http://localhost:1880/worldmap, it display the map.
Can you help me with what I should check/fix to make the tutorial works?
Following direction in this thread Problem node-red-contrib-web-worldmap did not help.
This is my node-red log on first start:
$ ./node_modules/.bin/node-red -u .
18 May 12:07:51 - [info]
Welcome to Node-RED
18 May 12:07:51 - [info] Node-RED version: v4.0.9
18 May 12:07:51 - [info] Node.js  version: v22.15.0
18 May 12:07:51 - [info] Linux 6.12.25-amd64 x64 LE
18 May 12:07:52 - [info] Loading palette nodes
18 May 12:07:52 - [info] FlowFuse Assistant Plugin is disabled
18 May 12:07:52 - [debug] logger Node logging turning on logging next 111 log points
18 May 12:07:52 - [info] logger Node Copyright 2020 Jaroslav Peter Prib
18 May 12:07:52 - [debug] logger Node test active
18 May 12:07:54 - [info] Worldmap version: 5.1.5
18 May 12:07:54 - [info] Dashboard version 3.6.5 started at /ui
18 May 12:07:54 - [info] Settings file  : /home/fhy/Workspace/node-red/settings.js
18 May 12:07:54 - [info] Context store  : 'default' [module=memory]
18 May 12:07:54 - [info] User directory : /home/fhy/Workspace/node-red
18 May 12:07:54 - [info] Projects directory: /home/fhy/Workspace/node-red/projects
18 May 12:07:54 - [info] Server now running at http://127.0.0.1:1880/
18 May 12:07:54 - [info] Active project : dummy
18 May 12:07:54 - [info] Flows file     : /home/fhy/Workspace/node-red/projects/dummy/flows.json
18 May 12:07:54 - [warn] Using unencrypted credentials
18 May 12:07:54 - [info] +-----------------------------------------------------
18 May 12:07:54 - [info] | uibuilder v7.2.0 initialised 🌐
18 May 12:07:54 - [info] | root folder: /home/fhy/Workspace/node-red/projects/dummy/uibuilder
18 May 12:07:54 - [info] | Using Node-RED's webserver at:
18 May 12:07:54 - [info] |   http://0.0.0.0:1880/
18 May 12:07:54 - [info] | Installed packages:
18 May 12:07:54 - [info] |   vue
18 May 12:07:54 - [info] Starting flows
18 May 12:07:54 - [info] [ui-base:Dashboard] Node-RED Dashboard 2.0 (v1.24.0) started at /dashboard
18 May 12:07:54 - [info] [ui-base:Dashboard] Created socket.io server bound to Node-RED port at path /dashboard/socket.io
18 May 12:07:54 - [info] [worldmap:b4f2e2dabd5b8220] started at /worldmap
18 May 12:07:54 - [info] Started flows
Thank you.
This is a regression that has been introduced in the current version of the dashboard.
I believe a fix is due very soon, in the meantime you could drop back to an earlier version
Yep, should have release reviewed and published tomorrow
Thank you Colin for the clarification.
Looking forward to trying the new release.
I uninstalled @flowfuse/node-red-dashboard@1.24.0
and installed @flowfuse/node-red-dashboard@1.23.0
Now worldmap can be displayed inside @flowfuse/node-red-dashboard-2-ui-iframe.
Thank you.
Nudge @joepavitt :wink:
Sorry, we've been away this week and I'm out of office until Wednesday. I may get a chance on Sundsy to do the release.
1.24.1 is now released with a fix in for this
I can view the worldmap by entering "localhost:1880/worldmap/" in the address bar of a new browser tab.
However, when I use the Dashboard 2.0 - i-frame node and enter "localhost:1880/worldmap/" in the URL field, the dashboard worldmap shows the error: "localhost redirected you too many times".
Versions:
Worldmap : 5.1.6
@flowfuse/node-red-dashboard : 1.24.1
Node-Red : 4.0.9
How can We fix this situation?
Thank you.
Did you recently update dashboard to v1.24.1? did you restart node-red and refresh the dashboard browser?
Hello Steve-Mcl,
I updated the Dashboard module. The current version is v1.24.1.
I also restarted the browser and Node-RED.
I just noticed a different situation:
When I open the dashboard in Google Chrome , I get the error:
"localhost redirected you too many times."
However, when I open the dashboard in Microsoft Edge, the worldmap displays successfully.
thats sounds like a cache issue. try clearing the other browsers cache for the dashboard.
In dev tools (F12)
