Thanks Ben. I wonder if I could trouble you to add that info to your otherwise very nice documentation?
So we now know that you do not need to worry about that and you do not need any inbound connections from the Internet.
Thanks to everyone for the nice advice and good information. I'm learning all the time.
Linux is good when you have to have something to occupy yourself with, not wife-friendly and there are other interests that are more interesting...
Thanks again to you all and for a nice tone in the correspondence.
Node-RED stopped using flows stored in a file that included the hostname a LONG time ago, I suggest you upgrade.
To clarify, we changed the default settings file to include a hard coded flow file name.
If you have an older settings file, then it likely won't have the flow filename set in it, so the runtime will still use the hostname to generate the file name.
So the fix is it to ensure your settings file sets the flow file name.
