The flows disappear
Hello.
I have a problem with node-red that I don't know what to do anymore.
Every so often, varying between two weeks and 2 or 3 days, the system deletes all the data in the flows.json file and the flows disappear.
Versions:
Node-RED v4.0.0
Node.js v20.14.0
MariaDb
MQTT
Debian without desktop
Distributor ID: Debian
Description: Debian GNU/Linux 12 (bookworm)
Release: 12
Codename: bookworm
Two months ago I changed from Raspberry Pi 3B to 4, I installed everything from scratch, but the problem persists.
I have a home automation application, temperatures, smoke detectors, etc., and I can't trust the system anymore.
Has anyone had the same problem?
Thanks for everything
Hi @XavierTGN, welcome to the forum.
Have you ever made your Node-red setup accessible from the internet?
Hello jbudd.
No, but can I copy it here?
Or should I put it on Github?
No no no, I don't want to access your Node-red, I wanted to find out if you might have been hacked, which would be possible if (for example) you had set up port forwarding on your router.
If I have port 1880 open to access from the Internet.
Is this file empty (completely)?
Locally in your network or open to internet (outside your network) ?
Sorry but that is ambiguous.
Do you now, or have you ever had port 1880 open to the internet?
Yes the file is empty, only .
Yes, I can acces from internet with the address public . Example
http://83.56.65.45:1880.
You have almost certainly been hacked.
Turn off port forwarding.
Reinstall the entire operating system on the Node-red device.
Check all of your computers for viruses.
If you restore Node-red from a backup, check all the flows for nodes you don't recognise, especially exec nodes. Note that these nodes might not be easily visible in the editor desktop.
Search the forum for advice on securing Node-red.
Password protect your editor.
Do not use port forwarding!
Ok. Now I close the ports and reinstall Debian and node-red,
Thanks for the advice
Congratulations on possibly being the first person to report Node-red v4 being hacked.
I hope the developers are taking note.
To misquote another forum post on this topic
V4.x stream is where it will might should be [wasn't] worked on.
Please remember to change any exposed passwords. Also, check anything else that is on your local network. For example, your router - if an attacker had access to Node-RED, they could easily have made changes to anything that they could access. Especially if you have used default logins for things like routers, the Pi, etc.
If you have other Raspberry Pies on the network they are probably especially likely to have been impacted,
