Flows do not survive a restart
I am running Node-Red version 1.2.7 on Raspberry Pi. This was initially installed as version 1.1.3
The initial install and subsequent upgrade were done using the recommended script from:
https://nodered.org/docs/getting-started/raspberrypi
Node-Red is setup to run as a service.
The .node-red folder appears as:
Node-Red-1.2.7-03-BeforeRestart
The following commands are issued from the Terminal:
node-red-stop
sudo reboot
After a the reboot, the .node-red folder appears as:
Node-Red-1.2.7-04-AfterRestart
New file items from version 1.2.7 of Node-Red are missing and the flow files are replace by much older files.
What is going on?
Where do the old files come from (i.e. where are they on the Pi)?
How do I stop this from happening (so that the system might survive a power failure) ?
Thanks.
Throw the SD card away and use a new one. It is quite a common mode of failure of the cards that they appear to work fine except that the new data is not being saved in the flash storage.
If it would save you a lot of time then it is probably ok to make an image copy of the old card onto the new one before you bin it. However it would be better to start from scratch and restore your flows file from your most recent backup onto the new card.
[Edit] Make sure you use a good quality branded SD card from a reputable source. Don't use cheap ones from ebay, it is a false economy.
Thank you ... sounds like a plausible solution. I happen to be using a "SanDisk High Endurance" card but anything can fail.
I have not been impressed with SanDisk, but stopped using them a few years ago so they may be ok now.
