Font awesom icons - stuck. (Stacking)
Looked here first:
Used the bottom one with the camera.
This is what I had and it works.
msg.payload = '<font color = yellow ><i class="fa fa-signing fa-flip-horizontal fa-2x"></i></font>';
This doesn't
msg.payload = '<font color = yellow > <span class="fa-stack"> <i class="fa fa-ban fa-2x fa-stack-1x"></i> <i class="fa-signing fa-2x fa-stack-2x"></i></span></font>';
Yes, I've removed the flip-horizontal.
Trying to find which part is making it not work.
I would also like to make the ban red.... But for now... I am not remembering things as well as i would like.
Where's the illusive elephant? :wink:
Not sure about your main question. But I can say that use of <font> is not recommended. Simply add style="color:yellow" to the <i> tag. That should fix your colour problem.
I'm guessing it is old code that I learnt way back when I first started.
And double checking, that link I posted doesn't have it either.
This is what the line has become ITMT - though I don't know it is nice to post it in light of what you said.
(Of course it still doesn't work)
msg.payload = '<font color = yellow > <span class="fa-stack"><i class="fa-signing fa-2x fa-stack-1x"></i> <i class="fa fa-ban fa-2x fa-stack-2x" style="color:Tomato"></i> </i></span></font>';
I'll give what you said a try and report back.
With this line:
msg.payload = '<span class="fa-stack"><i style="color:yellow" class="fa-signing fa-2x fa-stack-1x"></i> <i class="fa fa-ban fa-2x fa-stack-2x" style="color:Tomato"></i> </i></span></font>';
I get (picture)
Screenshot from 2024-06-10 19-29-26
So I'm guessing somewhere I have a lot of CSS stuff working.
But if I do all the styling in the line, that is LOCAL to that ..... button node.
(Alas the text node doesn't allow background colour setting.)
Taking a step back:
The ban is working.
The signning isn't.
but in the alternate line:
works.
:person_shrugging:
To maybe give a bigger picture here is the code and the button node:
[{"id":"832865263b1462a2","type":"function","z":"235f16ee6e459f2c","name":"Week check","func":"const timestamp = msg.payload\nconst weekno = Math.floor((timestamp + 345_600_000) / 604_800_000)\nconst result_ = Number(weekno) % 2\nif (result_ == 0) {\n    msg.payload = '<font color = yellow ><i class=\"fa fa-signing fa-flip-horizontal fa-2x\"></i></font>';\n    msg.flag = \"Wash\";\n    return msg;\n}\nelse\n{\n//    msg.payload = ' ';\n    msg.payload = '<span class=\"fa-stack\"><i style=\"color:yellow\" class=\"fa-signing fa-2x fa-stack-1x\"></i> <i class=\"fa fa-ban fa-2x fa-stack-2x\" style=\"color:Tomato\"></i> </i></span></font>';\n    msg.flag = \" \";\n}\nreturn msg;","outputs":1,"noerr":0,"initialize":"","finalize":"","libs":[],"x":1420,"y":4700,"wires":[["4e26090847259a9b","63e667ec355471b7"]]},{"id":"63e667ec355471b7","type":"ui_button","z":"235f16ee6e459f2c","name":"","group":"a71318e04a2701e3","order":14,"width":"1","height":"1","passthru":false,"label":"{{msg.payload}}","tooltip":"","color":"","bgcolor":"#333333","className":"","icon":"","payload":"","payloadType":"str","topic":"topic","topicType":"msg","x":1580,"y":4700,"wires":[[]]},{"id":"a71318e04a2701e3","type":"ui_group","name":"Special days","tab":"94541d8e64761d52","order":5,"disp":true,"width":"6","collapse":true,"className":""},{"id":"94541d8e64761d52","type":"ui_tab","name":"Messages","icon":"volume-up","order":13,"disabled":false,"hidden":false}]
fa-signing - seems to be an invalid entry. So that is probably the problem. You will want to make sure that it is part of the Fontawesome v4 library and not a later version.
Ok, thanks.
But...
(sorry)
(Stupid question)
I'm not making spelling mistake with the name?
But if the result is the opposite, and the other line is true:
I get the icon.
Which is confusing to me.
EDIT!
I'm missing the first fa !!??
Should be fa fa-signing......
I had only fa signing.....
Please check.
OH, but!
Colours not working.
function node complete code:
if (result_ == 0) {
    msg.flag = "Wash";
else
    msg.payload = '<span class="fa-stack"><i style="color:yellow" class="fa fa-signing fa-flip-horizontal fa-2x fa-stack-1x"></i> <i style="color:Tomato" class="fa fa-ban fa-2x fa-stack-2x"></i> </i></span></font>';
    msg.flag = " ";
So as is, the first one works and it IS yellow.
But in the (now) second case, I am now seeing both icons (stacked) but they are both white.
Your link shows fa-sign-language, not fa-signing - however, both appear to work (now I fixed my own error!)
This works:
<span class="fa-stack" style="color:red;">
  <i class="fa fa-signing fa-2x fa-stack-2x"></i>
</span>
As does this which may be even better for you. :slight_smile:
  <i class="fa fa-ban fa-2x fa-stack-1x" style="color:red;"></i>
  <i class="fa fa-signing fa-2x fa-stack-2x" style="color:yellow;"></i>
</span>
Better still:
    <i class="fa fa-signing fa-2x fa-stack-1x" style="color:yellow;"></i>
    <i class="fa fa-ban fa-2x fa-stack-2x" style="color:red;"></i>
</span>
I'll swap the stack positions so the ban is on top.
Ok, it's got weird.
It worked the first time and not subsequent times.
So I've stuffed something up.
Quick question though:
style = "color:red;"
I'm sure it worked.
Now I am not getting colours. :confused:
And I can put all those 4 lines into one as msg.payload = '<your code>
That is:
msg.payload = '<span class="fa-stack"> <i class="fa fa-signing fa-2x fa-stack-1x" style="color:yellow;"></i> <i class="fa fa-ban fa-2x fa-stack-2x" style="color:red;"></i> </span>'
Seems like an interaction with other code to me.
I am using UIBUILDER to test (of course!) rather than Dashboard but it should still work the same. Here was my final code:
        <div>
                <i class="fa fa-signing fa-2x fa-flip-horizontal fa-stack-1x" style="color:yellow;"></i>
            </span>
        </div>
This appears to be working consistently.
However, I am now questioning why you are sending this in a message? Why not have it in your front-end code and simply turn it on when needed?
Check the browser dev tools to look for console errors AND check the elements page to make sure that the resulting HTML is actually what you think it is. And check the specific element against its CSS to see if something is overriding the CSS settings.
Sorry, you lost me.
I've posted the code that controls which message is sent.
It checks if the week is odd or even numbered.
If odd, sends the hand.
If even, sends them but with a ban sign over the top.
(The actual odd/even: I'm not sure which is which.)
It is being sent as msg.payload to a button node set to receive {{msg.payload}} in the label field.
Ok, found a slight problem.
The button node had the background color field filled in with #333333.
Deleted, but no change.
Also, seems I was wrong wrt stacked icons.
I can't find any case now on 3 machines that have it.
I was sure I had it.
I'll have to check my MAIN machine.
But that has about 30 pages (GUI) so it is going to take a while.
Sorry
Did some digging. Found an example!
But it uses a template node and all the code is in there.
Not sent to it.
If I copy the template and put your code it in on the desired machine, it works.
(PROBLEM)
I can't change the symbol.
Other thing noticed:
If I send it as a message, it is monochrome. :confounded:
FURTHER TESTING
If I put two template nodes and have one with the hands and the other with your code they BOTH work 100%
So now I have to try and work out what is preventing the node accept a msg.payload and displaying it correctly.
To be clear: This needs to be in the template node to pares the message:
<div ng-bind-html="msg.payload"></div>
Why not simply add both sets of html to the template and & use payload to show 1 & hide the other.
Sending html is archaic and unmaintainable and as you have found, problematic.
Thanks @Steve-Mcl .
Alas as I am not doing this all the time I don't know/remember how to do it.
So if I am using a template node (seems the only way I can get it working) would you please show me an example of how to do this?
This is what I understand to this point in time.
<style>
    .wash
        <i class="fa fa-signing fa-flip-horizontal fa-2x" style="color:yellow"></i>
    .nowash
        </span>
</style>
That sets the two definitions
But now I fall apart as I don't know the magic to parse the {{payload}} and display the relevant style.
So you could simply have everything already in place so you don't have to keep sending HTML all the time. Just send it once in your ui_template and turn it on/off by just changing the class from a hidden to a visible style. This is the HTML way, not constantly sending more and more HTML to all the connected clients.
:+1: Actually, you only need 1 set of HTML, just turn on/off the bits you need. That's one of the great strengths of CSS and classes.
Yes, I sort of understand the idea.
But the mechanics of doing that.....
That last post is 'css' - I'm guessing.
And it won't do the job, but MAY be the start of it.
Doing it with HTML... That's a whole other ball game.
I've never really done anything with it and even less knowledgeable.
Help please.
Just to show I'm not dumping it on anyone:
let week = msg.payload
if (week == 0)
    <i class="fa fa-signing fa-flip-horizontal fa-2x"style="color:yellow"></i>
else
if (week == 1)
    <span class="fa-stack"><i class="fa fa-signing fa-2x fa-flip-horizontal fa-stack-1x"style="color:yellow;"></i><i class="fa fa-ban fa-2x fa-stack-2x"style="color:red;"></i></span>
But it doesn't quite work.
I get the icon but also a lot of text.
Not sure of the exact mechanism for setting CSS Classes with Dashboard 2 (if that is what you are using). But in general all you need is 1 set of html:
        </span>
And a css class:
.hidden {
  display: none;
Then just add the hidden class to the second <i>
          <i class="hidden fa fa-ban fa-2x fa-stack-2x" style="color:red;"></i>
        </span>
With standard VueJS, you can make any attribute dynamic using v-bind or simply : as in:
          <i v-bind:class="somejsvariable" style="color:red;"></i>
Now you control the 2nd icon using a JavaScript variable that you set as a data variable in VueJS to make it responsive.
I think that's the way anyway, been a while since I used VueJS.
I don't even what what vueJS is.
And I am using the original dashboard. Not the new fuse one.
Ah, sorry, I made the wrong assumption. D2 uses the VueJS v3 front-end framework. D1 uses the AngularJS v1.
AnglularJS also has the ability to have dynamic attributes. I think you can just use mustaches inside the attribute value? Been a long time since I did anything serious with Anglular though I'm afraid.
Maybe:
          <i class="{{isHidden}} fa fa-ban fa-2x fa-stack-2x" style="color:red;"></i>
        </span>
Where isHidden is a variable. (all untried I'm afraid).
or: <i ng-if="showBan" class="fa fa-ban
and send a message with showBan true / false
Thanks @Steve-Mcl and @TotallyInformation.
Alas I shall have to admit I am still not understanding.
Steve,
I'm taking it that your or line continues on how Julian said - yes?
So I used two inject nodes.
msg.showBan = true and msg.showBan = false
Nothing happens.
Oh, the code - for clarity:
          <i ng-if="showBan" class="fa fa-ban fa-2x fa-stack-2x" style="color:red;"></i>
        </span>
