Chatted with @xytsrm he found an answer and I thought it was a good question for future readers so opened to allow a response.
here is the chat
Me
Hi, That is a good question. I take it you figured out not to declare let again inside the if block.
xytsrm
Yes, exactly. I don't use Java script too often, I'm far more familiar with Python where there are no explicit declarations. Also, I learned that if you want a variable to be global outside the if-block you need to declare it before the if-block. There was an archaic programming language that I used decades ago where you needed to use "let" all the time, for declarations & assignments; I think that was blinding me to the "let" statements in the if-block.
The funny thing is I summited that code sample to ChatGPT, before I made the declaration prior to the if-block. ChatGPT said the code looked ok, but I needed to make the declaration before the if-block. BUT, then it reprinted my code WITHOUT the "let" in the if-block. Can you believe I still missed the removal of the "let"; it never explicitly said you need to remove the "let" - lol.
Regarding leaving the question on the forum as a "learning experience" you right I probably should have, but I was so embarrassed by what I came to see as an obvious error, I hastily deleted it; I'll consider un-deleting it.
Me
If you want a global var declare it with var name;
Mistakes are easy to overlook we have all been there
This is a great community and I would not worry about embarrasment, there are no stupid questions when learning.
xytsrm
Thanks for the encouragement - lol
Interestingly, I found the either let, or var works, but you're right var is preferred. I had tried the 'var' but it made no difference to the error, but that was before I realized the real error; the 'let' in the if-block.
Me
var is global and will be available any where
let is confined in the { } block only or global if defined outside any { }
preference
is
const
let
var
in that order
const means the var will not change, object defined const must always be an object but you can redefine the properties.
