Panda
21 September 2024 12:53
1
Hey guys,
I want to make a form in the template node and then make an output for the next node. Unfortunately I can't get it right, do any of you have an idea where the problem is?
Thanks in advance
<style>
.input-container {
margin-bottom: 15px;
.input-label {
display: block;
margin-bottom: 5px;
.my-class {
color: red;
</style>
<template>
<div>
<div class="input-container">
<label class="input-label">Abschlag (€):</label>
<input type="number" id="abschlag" placeholder="Abschlag in €" />
</div>
<label class="input-label">Arbeitspreis (ct/kWh):</label>
<input type="number" id="arbeitspreis" placeholder="Arbeitspreis in ct/kWh" />
</div>
<label class="input-label">Grundpreis (€):</label>
<input type="number" id="grundpreis" placeholder="Grundpreis in €" />
</div>
<label class="input-label">Zählerstand:</label>
<input type="number" id="zaehler" placeholder="Zählerstand" />
</div>
<button class="my-class" onclick="onClick()">Daten senden</button>
</template>
<script>
window.onClick = function () {
const abschlag = document.getElementById('abschlag').value;
const arbeitspreis = document.getElementById('arbeitspreis').value;
const grundpreis = document.getElementById('grundpreis').value;
const zaehlerstand = document.getElementById('zaehler').value;
const msg = {
abschlag: abschlag,
arbeitspreis: arbeitspreis,
grundpreis: grundpreis,
zaehler: zaehlerstand
alert('Daten gesendet: ' + JSON.stringify(msg));
this.send(msg);
</script>
docs: UI Template Examples | Node-RED Dashboard 2.0
<template>
<div>
<input type="number" v-model="abschlag" placeholder="Abschlag in €" />
</div>
<input type="number" v-model="arbeitspreis" placeholder="Arbeitspreis in ct/kWh" />
</div>
<input type="number" v-model="grundpreis" placeholder="Grundpreis in €" />
</div>
<input type="number" v-model="zaehler" placeholder="Zählerstand" />
</div>
<button class="my-class" @click="onClick">Daten senden</button>
</template>
<script>
export default {
data() {
return {
abschlag: '',
arbeitspreis: '',
grundpreis: '',
zaehler: ''
methods: {
onClick: function () {
this.msg.payload = {
abschlag: this.abschlag,
arbeitspreis: this.arbeitspreis,
grundpreis: this.grundpreis,
zaehler: this.zaehler
this.send(this.msg);
</script>
<style>
.input-container {
.input-label {
display: block;
margin-bottom: 5px;
.my-class {
color: red;
</style>
And if you want it to look native, the use the vuetify components
Panda
21 September 2024 13:32
4
Thanks man, I just start using the template node today, I think there is many to learn for me
Panda
21 September 2024 14:12
5
Ok, next step but sorry for my dump question. But how can I replace the "placeholder"
by msg.payload.abschlag.
ChatGPT cant help me.
I tried:
{{msg.payload.abschlag}}
and
export default {
data() {
return {
abschlag: '',
phabschlag: '',
arbeitspreis: '',
grundpreis: '',
zaehler: ''
mounted() {
// Abruf von flow.get('zaehler') bei der Initialisierung und sicherstellen, dass es eine Zahl ist
this.phabschlag = msg.payload; // Standardwert, falls flow.get kein Ergebnis liefert
As dashboard is built on Vue, you can use attribute binding - it's in the docs too: Template ui-template | Node-RED Dashboard 2.0
<input type="number" v-model="abschlag" :placeholder="msg.whatever" />
Panda
21 September 2024 15:30
7
I don't get it, I tried this allready and it didn't work. Now it's working, thanks again
