Forms Entry disappearing
I have a forms entry UI on my dashboard. I can enter values into it. Great! But is there a way to make my entry stay after I hit the submit button? I can enter values into it. It outputs and does its thing, but the value disappears.
        "id": "b3b62da05decf94d",
        "type": "tab",
        "label": "Flow 2",
        "disabled": false,
        "info": "",
        "env": []
        "id": "a311d9f438ce0a32",
        "type": "ui_form",
        "z": "b3b62da05decf94d",
        "label": "Int Number",
        "group": "88145eb0.23895",
        "order": 13,
        "width": 0,
        "height": 0,
        "options": [
                "label": "wut is this",
                "value": "value",
                "type": "number",
                "required": true,
                "rows": null
        "formValue": {
            "value": ""
        "payload": "",
        "submit": "submit",
        "cancel": "cancel",
        "topic": "topic",
        "topicType": "msg",
        "splitLayout": "",
        "className": "",
        "x": 310,
        "y": 200,
                "67208e39cf9f055f"
        "id": "d44340b8689c7a1f",
        "type": "modbus-response",
        "registerShowMax": 20,
        "x": 1050,
        "y": 280,
        "id": "423984e8b3c26593",
        "type": "modbus-flex-write",
        "showStatusActivities": false,
        "showErrors": false,
        "showWarnings": true,
        "server": "bf81420f.323c4",
        "emptyMsgOnFail": false,
        "keepMsgProperties": false,
        "delayOnStart": false,
        "startDelayTime": "",
        "x": 830,
        "y": 280,
                "d44340b8689c7a1f"
        "id": "67208e39cf9f055f",
        "type": "function",
        "name": "function 4",
        "func": "var value = msg.payload.value\nvar buf = Buffer.alloc(4);\nbuf.writeFloatBE(value);\nvar values = [(buf[2]*256) + buf[3], (buf[0]*256) + buf[1] ]\n\nmsg.payload = \n{ value: values, \n'fc': 16, \n'unitid': 1, \n'address': 28688 , \n'quantity': 2 } \n\nreturn msg",
        "outputs": 1,
        "timeout": 0,
        "noerr": 0,
        "initialize": "",
        "finalize": "",
        "libs": [],
        "x": 600,
        "y": 200,
                "423984e8b3c26593",
                "8cc33af046999468"
        "id": "8cc33af046999468",
        "type": "debug",
        "active": true,
        "tosidebar": true,
        "console": false,
        "tostatus": false,
        "complete": "false",
        "statusVal": "",
        "statusType": "auto",
        "x": 950,
        "y": 140,
        "id": "88145eb0.23895",
        "type": "ui_group",
        "name": "PLC_Read",
        "tab": "a9e24f558660ab0d",
        "order": 1,
        "disp": true,
        "width": "8",
        "collapse": false,
        "className": ""
        "id": "bf81420f.323c4",
        "type": "modbus-client",
        "name": "PLC",
        "clienttype": "tcp",
        "bufferCommands": true,
        "stateLogEnabled": false,
        "queueLogEnabled": false,
        "failureLogEnabled": false,
        "tcpHost": "192.168.0.10",
        "tcpPort": "502",
        "tcpType": "DEFAULT",
        "serialPort": "/dev/ttyUSB",
        "serialType": "RTU-BUFFERD",
        "serialBaudrate": "9600",
        "serialDatabits": "8",
        "serialStopbits": "1",
        "serialParity": "none",
        "serialConnectionDelay": "100",
        "serialAsciiResponseStartDelimiter": "",
        "unit_id": 1,
        "commandDelay": 1,
        "clientTimeout": 1000,
        "reconnectOnTimeout": true,
        "reconnectTimeout": 2000,
        "parallelUnitIdsAllowed": true,
        "showLogs": true
        "id": "a9e24f558660ab0d",
        "type": "ui_tab",
        "name": "MAIN",
        "icon": "dashboard",
        "order": 2,
        "disabled": false,
        "hidden": false
Feed the output message back to the input.
Yes! I did had to manipulate the output, then loop back to the input. Thanks!
