I couldn't see any posts for this. I know I can use ctrl v but do miss paste from the RMB menu.
This is a browser / monaco issue.
Read: Monaco editor, missing "Paste" command - #2 by Steve-Mcl
Sorry not sure why I didn't find that post
It might be resolved in latest version of monaco.
could you try right click copy, right click paste in the monaco playground?
Also, how are you accessing node-red in the browser? http/https? localhost?
No joy there with FF but does work with Chrome
Yes, FF is a pain. Does it work on your node-red in chrome?
Could you also answer ...
NR is NOT working in Chrome Version 98.0.4758.81 (Official Build) (64-bit)
Its not secure - http/
http://localhost:1880 or http://IP_ADDRESS:1880 or http://some-domain:1880 or ... ?
and if it is IP address is it the browser on the same machine as node-red is running?
Working in
Microsoft Edge
Version 97.0.1072.76 (Official build) (64-bit)
Of course it initially asks for permission and if you didn't give it sometime, you'd need to reset the permissions.
http:/192.168.1.xxx:1880/# ie remote machine
Julian...
Is browser on same machine as node-red?
Is the URL http / https?
using IP or name?
via proxy / across internet or LAN? / direct?
Does the remote machine have a browser you could test using http://localhost:1880?
I'd like to understand if this is related to security etc.
Sorry, should have said.
Works both on same localhost with Node-RED and with Node-RED on another host. localhost is http remote is https. I use http://127.0.0.1:1880/red/#flow/bbba670ae518c0ec for the localhost and https://home.knightnet.co.uk:1880/red/#flow/ff1a7711.244f48 (and in case you are wondering - no that URL isn't externally accessible, it was just a spare domain so I used it for Let's Encrypt).
Ok, I think I understand the issue now.
Thanks.
