hello,
from an mqtt node, I need to send payload to the telegram node but only each hour.
Could you advice me how to process ?
thanks,
You could use a delay node set to rate limit mode, once an hour, discard intermediate messages.
hello, after on hour all messages are again sent to telegram.
You probably have the delay node set to delay mode. It should be set to rate limit as explained by @Colin
oops yes now it's ok. thanks for your help. The community power !
