How to make sure that only one message is sent every few minutes
When a certain MQTT message arrives, Pushover sends a message. When a trigger sends MQTT messages in short succession, far too many messages are received.
Do you know what the best way is to build in a delay so that the next message is only sent after 5 minutes? In other words, no more than one message may be sent every 5 minutes.
MQTT
Hi @HaVi
Use the delay Node in Rate Limit Mode
Screenshot 2024-05-29 at 17.16.17
Thanks Marcus, that's exactly what I needed and it works perfectly :slight_smile:
