From MSSQL to csv to email
Hello, little problem here. I'm reading data from MSSQL and I want them to put in csv file(create that file and put in) and after that send that by email. I think it should be easy but I can't figure that.
Here are my nodes
[{"id":"b965d0f.146f13","type":"inject","z":"f2c4701d.a13f6","name":"","topic":"","payload":"","payloadType":"date","repeat":"","crontab":"","once":true,"onceDelay":0.1,"x":150,"y":580,"wires":[["6d561629.287b28"]]},{"id":"6d561629.287b28","type":"MSSQL","z":"f2c4701d.a13f6","mssqlCN":"7d98b4ae.aae53c","name":"","query":"SELECT TOP (100) [Pc]\n ,[Datum]\n ,[Cislo_elmeru]\n ,[Hodnota_T1]\n ,[Hodnota_T2]\n FROM [scdb].[dbo].[elmery] ORDER BY Datum DESC","outField":"payload","x":310,"y":600,"wires":[["9cad07f5.3e5248"]]},{"id":"9cad07f5.3e5248","type":"csv","z":"f2c4701d.a13f6","name":"","sep":",","hdrin":true,"hdrout":false,"multi":"one","ret":"\\n","temp":"Pc,Datum,Cislo_elmeru,Hodnota_T1,Hodnota_T2","skip":"0","x":490,"y":640,"wires":[["53539f45.fe98e"]]},{"id":"53539f45.fe98e","type":"e-mail","z":"f2c4701d.a13f6","server":"smtp.gmail.com","port":"465","secure":true,"name":"","dname":"","x":880,"y":640,"wires":[]},{"id":"7d98b4ae.aae53c","type":"MSSQL-CN","z":"","name":"scdb","server":"185.58.41.21","encyption":true,"database":"scdb"}]
The output of the CSV node says...
If the input is an array of arrays, or an array of objects, a multiple-line CSV string is created.
The built in help for email node says...
If the payload is a binary buffer then it will be converted to an attachment.
So try adding a function node between CSV and Email
//set payload to a buffer
msg.payload = Buffer.from(msg.payload);
I did what you said, now I receive on email file but it's not .csv it's .bin and I can't open it in Excel for example. I also tried instead of csv node Excel node (node-red-contrib-excel) but when I open it in Excel it's clear.
The file is fine - it just needs to be renamed to xxx.csv.
The Email node says...
If the payload is a binary buffer then it will be converted to an attachment. The filename should be set using msg.filename
and
with a subject of msg.topic
so add that to the function node...
msg.topic = "Sensor data attached"
msg.filename = "data.csv"
Here is a working example I knocked up...
[{"id":"a14fc6ed.f35998","type":"inject","z":"f1d1607b.077aa","name":"Simulated data","topic":"","payload":"[{\"colour\":\"red\",\"value\":\"#f00\"},{\"colour\":\"green\",\"value\":\"#0f0\"},{\"colour\":\"blue\",\"value\":\"#00f\"},{\"colour\":\"cyan\",\"value\":\"#0ff\"},{\"colour\":\"magenta\",\"value\":\"#f0f\"},{\"colour\":\"yellow\",\"value\":\"#ff0\"},{\"colour\":\"black\",\"value\":\"#000\"}]","payloadType":"json","repeat":"","crontab":"","once":false,"onceDelay":0.1,"x":140,"y":460,"wires":[["89849c13.01d3e"]]},{"id":"89849c13.01d3e","type":"csv","z":"f1d1607b.077aa","name":"","sep":",","hdrin":false,"hdrout":true,"multi":"one","ret":"\\n","temp":"colour,value","skip":"0","x":290,"y":460,"wires":[["73812b52.25b8d4"]]},{"id":"4c5ed49.07eb82c","type":"e-mail","z":"f1d1607b.077aa","server":"smtp.gmail.com","port":"465","secure":true,"tls":false,"name":"","dname":"","x":730,"y":460,"wires":[]},{"id":"79d99799.5e6318","type":"debug","z":"f1d1607b.077aa","name":"","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"true","targetType":"full","x":590,"y":500,"wires":[]},{"id":"73812b52.25b8d4","type":"function","z":"f1d1607b.077aa","name":"Set filename and convert to buffer","func":"msg.topic = \"Sensor data attached\"\nmsg.filename = \"data.csv\"\nmsg.payload = Buffer.from(msg.payload);\nreturn msg;","outputs":1,"noerr":0,"x":500,"y":460,"wires":[["79d99799.5e6318","4c5ed49.07eb82c"]]}]
I would like to create a report about my water temperature over the whole day and send it to me as a CSV-file via email, to analyze it. To do this, I found you flow, which I want to use a base.
I modified the flow as followed.
[{"id":"89d6a749.8a08d8","type":"inject","z":"ecbfd3ca.f6ae7","name":"Simulated data","props":[{"p":"timestamp","v":"","vt":"date"}],"repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"","x":113,"y":517,"wires":[["9e220d54.1c1f3"]]},{"id":"9e220d54.1c1f3","type":"random","z":"ecbfd3ca.f6ae7","name":"Temp Water","low":"-5","high":"45","inte":"true","property":"payload","x":348,"y":502,"wires":[["3a52282c.1a2658"]]},{"id":"3a52282c.1a2658","type":"function","z":"ecbfd3ca.f6ae7","name":"Set filename and convert to buffer","func":"[\n {\n \"Time\": msg.timestamp,\n \"value\": msg.payload,\n },\n \n]\nreturn msg; ","outputs":1,"noerr":0,"initialize":"","finalize":"","x":250,"y":365,"wires":[["69326278.0b2f4c","1fe3bda5.426d22"]]},{"id":"1fe3bda5.426d22","type":"csv","z":"ecbfd3ca.f6ae7","name":"","sep":",","hdrin":false,"hdrout":"all","multi":"one","ret":"\\n","temp":"colour,value","skip":"0","strings":true,"include_empty_strings":false,"include_null_values":false,"x":427,"y":257,"wires":[["cf0afa9c.fed218"]]},{"id":"cf0afa9c.fed218","type":"function","z":"ecbfd3ca.f6ae7","name":"Set filename and convert to buffer","func":"msg.topic = \"Sensor data attached\"\nmsg.filename = \"data.csv\"\nmsg.payload = Buffer.from(msg.payload);\nreturn msg;","outputs":1,"noerr":0,"initialize":"","finalize":"","x":710,"y":243,"wires":[["e0f2f93d.3eb938","619eada2.872754","6a643f74.988d7"]]},{"id":"6a643f74.988d7","type":"e-mail","z":"ecbfd3ca.f6ae7","server":"smtp.gmail.com","port":"465","secure":true,"tls":true,"name":"","dname":"","x":918,"y":379,"wires":[]}]
Timestamp and payload are variable in this case and I can´t manage that the CSV node includes them.
Do you know I a can solve this problem?
Thanks in advance :slight_smile:
Hi. First, you flow cannot be imported. In order to make code more readable and importable it is important to surround your code with three backticks
like this
You can edit and correct your post by clicking the pencil icon.
That's not really clear. What is your issue? Does the email arrive? Does it have a csv attachment? Does the attachment have your data?
try this...
[{"id":"a14fc6ed.f35998","type":"inject","z":"83a23089.dc697","name":"Simulated data","props":[{"p":"payload"},{"p":"topic","vt":"str"}],"repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"","payload":"true","payloadType":"bool","x":295,"y":900,"wires":[["3af75735.9c7b28"]],"l":false},{"id":"89849c13.01d3e","type":"csv","z":"83a23089.dc697","name":"","sep":",","hdrin":false,"hdrout":"all","multi":"one","ret":"\\n","temp":"Timestamp,payload","skip":"0","strings":true,"include_empty_strings":false,"include_null_values":false,"x":610,"y":900,"wires":[["73812b52.25b8d4","594171aa.dfd1e"]]},{"id":"4c5ed49.07eb82c","type":"e-mail","z":"83a23089.dc697","server":"smtp.gmail.com","port":"465","secure":true,"tls":false,"name":"","dname":"","x":1050,"y":900,"wires":[]},{"id":"79d99799.5e6318","type":"debug","z":"83a23089.dc697","name":"","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"true","targetType":"full","x":950,"y":960,"wires":[]},{"id":"73812b52.25b8d4","type":"function","z":"83a23089.dc697","name":"Set filename and add content","func":"msg.attachments = [\n    {\n        filename : \"data.csv\",\n        content: Buffer.from(msg.payload),\n    }\n]\n\nmsg.topic = \"Sensor data\";\nmsg.payload = \"See data.csv attached\"\n\nreturn msg;","outputs":1,"noerr":0,"initialize":"","finalize":"","libs":[],"x":800,"y":900,"wires":[["79d99799.5e6318","4c5ed49.07eb82c"]]},{"id":"3af75735.9c7b28","type":"function","z":"83a23089.dc697","name":"generate random data","func":"var rowCount = 200;\nvar data = [];\nfor (let index = 0; index < rowCount; index++) {\n    const row = {\n        Timestamp: (Date.now())/(1000*60*60*24)+25569, //convert hs timestamp (Date.now()) to excel date number\n        payload: \"random number - \" + (Math.random() * 10)\n    }\n    data.push(row);\n}\nmsg.payload = data;\nreturn msg;","outputs":1,"noerr":0,"initialize":"","finalize":"","libs":[],"x":440,"y":900,"wires":[["89849c13.01d3e"]]},{"id":"594171aa.dfd1e","type":"debug","z":"83a23089.dc697","name":"","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"payload","targetType":"msg","statusVal":"","statusType":"auto","x":750,"y":960,"wires":[]}]
