From SQL database to UI bar chart
I have an SQL query which produces this output:
[{"id":1,"month":"january","temperature":65},{"id":2,"month":"january","temperature":28},{"id":3,"month":"january","temperature":38},{"id":4,"month":"february","temperature":59},{"id":5,"month":"february","temperature":48},{"id":6,"month":"february","temperature":38},{"id":7,"month":"march","temperature":80},{"id":8,"month":"march","temperature":40},{"id":9,"month":"march","temperature":20},{"id":10,"month":"april","temperature":81},{"id":11,"month":"april","temperature":19},{"id":12,"month":"april","temperature":49},{"id":13,"month":"may","temperature":56},{"id":14,"month":"may","temperature":86},{"id":15,"month":"may","temperature":45},{"id":16,"month":"june","temperature":55},{"id":17,"month":"june","temperature":27},{"id":18,"month":"june","temperature":40},{"id":19,"month":"july","temperature":40},{"id":20,"month":"july","temperature":90},{"id":21,"month":"july","temperature":20}]
I want to display it as this chart (data and chart form one of the examples at the library flow Populate full dashboard chart )
So it has to be converted to this format
var m={};
m.labels = ["January", "February", "March", "April", "May", "June", "July"];
m.series = ['Series A', 'Series B', 'Series C'];
m.data = [
    [65, 59, 80, 81, 56, 55, 40],
    [28, 48, 40, 19, 86, 27, 90],
    [38, 28, 20, 49, 45, 60, 20]
return {payload:[m]};
I can't work out how to transform the SQL output into the chart input arrays, can anyone help?
Edit - I can change the SQL to also output "Series A" etc, not sure if that helps.
Something like this jbudd.
const series_count = msg.payload.reduce((a,v) => (v.month === msg.payload[0].month ? a+1 : a),0)
let labels =[];
let series =[];
let data = [];
for(let h=0; h<series_count; h++){
    series.push("series " + (h+1));
    data[h] = [];
for(let i=0; i<msg.payload.length; i += series_count){
    labels.push(msg.payload[i].month);
    for(let j=0; j<series_count; j++){
        data[j].push(msg.payload[i+j].temperature);
msg.payload=[{
    series,labels,data
Oh thats excellent, thanks @E1cid.
I was trying to process each payload atom individually, I wish I'd thought of doing it in chunks with i += series_count, so much easier!
Here is your function again prolifically annotated for my future reference.
// series_count = 3
let labels =[];
let series =[];
let data = [];
// Setup Series
    data[h] = [];
// now series = ["Series 1", "Series 2", "Series 3"]
// data = [ [], [], [] ]
    // (msg.payload.length = 21)
    // msg.payload[n]   = eg {"id":1,"month":"january","temperature":65}
    // msg.payload[n+1] = eg {"id":2,"month":"january","temperature":28}
    // msg.payload[n+2] = eg {"id":3,"month":"january","temperature":38}
        //data[0].push(65)
        //data[1].push(28)
        //data[2].push(38)
// now labels = ["january", "february", ... "july"]
// data = [[65,59,80,81,56,55,40],[28,48,40,19,86,27,90],[38,38,20,49,45,40,20]]
msg.payload=[{
    series,labels,data
