Function editor, error reporting has strange behavour
Hi, I worked a lot with NR @version 2, I do remember how it helped me correcting syntax, remember missing pharentesis and so on. Now I?m using 4, I have an error somewhere and I can't get rid of it. I can see NR reporting somethin in small, but I can't enlarge, I can't click, no interaction, I can't do nothing with that. I'm a bit suroprised somebody introducted something that warn but it's completely useless... so I guess I just don't know how to deal with that. I know I can change editors, but before I would now how to make this work. Thank you
erroree
That is just the minimap. When you have lots of code scrolled off the screen it lets you see at a glance if there are errors. To the left of the minimap will be your regular code (where you type and edit). The errors will be highlighted with squiggles which if you put the mouse over will tell you what is wrong.
Show us your code.
Thanks, now I understand, I've to become addicted )
