If you enter the following into a function node, no statement is flagged in the editor:
msg.payload = 0755
However when you look at the flow diagram, the function node is flagged (red triangle) with a noerr:
and you get a message at deploy time:
and if you do deploy, the node works correctly:
@dceejay or @knolleary bug??
