"Invalid properties: Error in JavaScript Code" in Function Node but Function works
I am trying to use a Function Node to pull a stored temperature value and format it so that I can send it to a Call Service Node in Home Assistant. This code works just as I want. However, the Function Node has a Red Triangle and the error says "Invalid properties: Error in JavaScript Code". Then, I have to deal with the warning every time I deploy
Any ideas? I am sure it is something simple. I rarely, if ever, use function nodes so I am a newbie with them.
var currentT = Number(flow.get("current1stFloorSP"));
node.warn("currentT: " + currentT);
newmsg = {
    payload: {
        data: {
            "temperature": currentT
return newmsg;
You have not declared newmsg, which will still work but is poor JS coding.
If you are using monaco editor, then the red undulating underlining should have given you a clue.
As @E1cid suggested, you need to declare 'newmsg'.
Try this... and see if the red triangle goes away.
I am sure that I do a lot of that w/ my limited knowledge of it. :grin:
Adding const worked. Thank you both. I knew it was something simple.
If you use the error checking of the editor, it shows error and gives suggestions
