Function node - what happens if I don't "return" anything?
I know I am asking for it by asking, but in light of wanting to learn.....
It probably isn't the reason, but I want to be sure.
My poor RPI is (I am told) running way to hard (60-70% load peaking.)
Now and then it goes up to 100% but only for a while.
Anyway, here's my question:
(Example code only)
(Hand written not real code, but only for showing the problem as I see it)
var x = msg.payload;
if (x == "foo")
   msg.payload = "Option 1";
else
if (x == "boo")
  msg.payload = "Option 2";
Which has not worried me until now.
If the message is neither "foo" or "boo" then nothing is sent.
That is what is wanted/needed.
Until know I thought (stupidly) that you had to return msg;
But a simple return is also allowed.
Though I have to admit, I don't get what is returned.
If I have a few (dozen) nodes without the final return would that cause problems?
Gotta ask to be sure.
A return by itself, return null, and no return at the end at all, all do the same, no message is sent.
Ok, that resolves that suspicion.
Easily tested though - you need to have confidence in your ability to test :slight_smile:
Yeah, as someone once said:
(this applies to me....)
I am good at testing dumb things I do.
But, I try to see the bright side of it. I am learning.
