Function programming help
Hi Guys, im new to Node Red and hooked up my Smartmeter. Now i want to isolate this Value on the button. But how can i do it over the function node. Sorry i have non coding skills and this is my last problem to solve
the Path is:
payload["1-0:16.7.0*255"].values[0].value
Hi @Nick94.
What do you mean by isolate this value on the button? Exactly what do you want to do with the value?
i want to pull the marked value. I only need this for my planned Control system. Do you know what i mean?
Hi Nick
You can move or copy the value to msg.payload using a change node.
Also, in case you are not aware, there’s a great page in the docs (Working with messages : Node-RED) that will explain how to use the debug panel to find the right path to any data item.
BX00Cy7yHi
I recommend watching this playlist: Node-RED Essentials. The videos are done by the developers of node-red. They're nice & short and to the point. You will understand a whole lot more in about 1 hour. A small investment for a lot of gain.
i tried it with the change node and it works fine. Thank you!
