Split value from an object
hello!
i'm new with node red
i want to know how to sent the value only
the function in the photo is empty
thanks alot
If you want to set/move a value to msg.payload, it would be best to use a change node. using a function node is over kill.
In the change node -
1 select move
2 then select msg enter the path to the value, in this case it would be payload.value[0]. The docs tell you how to get the path here.
3 in the to section select msg and enter payload
If you must use a function node, it would be
msg.payload = msg.payload.value[0];
There’s a great page in the docs that will explain how to use the debug panel to find the right path to any data item.
BX00Cy7yHi
https://nodered.org/docs/user-guide/messages
I recommend watching this playlist: Node-RED Essentials. The videos are done by the developers of node-red. They're nice & short and to the point. You will understand a whole lot more in about 1 hour. A small investment for a lot of gain.
Thank you very much Sir
Thank you very much Sir!
I will watch it
