Function with a lot of output?
Hello everyone .
I have a function with 88 outputs.
the source comes from a modbus output as an array.
in the function I insert a topic on each value.
is there a simpler way to do this?
var x1 = { payload: msg.payload.data[0]/2}; /*var x   = { payload: msg.payload.data[]};*/
var x2 = { payload: msg.payload.data[1]};
var x3 = { payload: msg.payload.data[2]/2};
var x4 = { payload: msg.payload.data[3]/10};
var x5 = { payload: msg.payload.data[4]};
var x6 = { payload: msg.payload.data[5]/2};
var x7 = { payload: msg.payload.data[6]};
var x8 = { payload: msg.payload.data[7]};
var x9 = { payload: msg.payload.data[8]};
var x10 = { payload: msg.payload.data[9]};
var x11 ={  payload: msg.payload.data[10]};
var x12 = { payload: msg.payload.data[11]};
var x13 = { payload: msg.payload.data[12]};
var x14 = { payload: msg.payload.data[13]};
var x15 = { payload: msg.payload.data[14]};
var x16 = { payload: msg.payload.data[15]};
var x17 = { payload: msg.payload.data[16]};
var x18 = { payload: msg.payload.data[17]};
var x19 = { payload: msg.payload.data[18]};
var x20 = { payload: msg.payload.data[19]};
var x21 = { payload: msg.payload.data[20]};
var x22 = { payload: msg.payload.data[21]};
var x23 = { payload: msg.payload.data[22]};
var x24 =  { payload: msg.payload.data[23]};
var x25 = { payload: msg.payload.data[24]};
var x26 = { payload: msg.payload.data[25]};
var x27 = { payload: msg.payload.data[26]};
var x28 = { payload: msg.payload.data[27]};
var x29 = { payload: msg.payload.data[28]};
var x30 = { payload: msg.payload.data[29]};
var x31 = { payload: msg.payload.data[30]};
var x32   = { payload: msg.payload.data[31]};
var x33  = { payload: msg.payload.data[32]};
var x34   = { payload: msg.payload.data[33]};
var x35   = { payload: msg.payload.data[34]};
var x36   = { payload: msg.payload.data[35]};
var x37   = { payload: msg.payload.data[36]};
var x38   = { payload: msg.payload.data[37]};
var x39   = { payload: msg.payload.data[38]};
var x40   = { payload: msg.payload.data[39]};
var x41   = { payload: msg.payload.data[40]};
var x42   = { payload: msg.payload.data[41]};
var x43   = { payload: msg.payload.data[42]};
var x44   = { payload: msg.payload.data[43]};
var x45   = { payload: msg.payload.data[44]};
var x46   = { payload: msg.payload.data[45]};
var x47   = { payload: msg.payload.data[46]};
var x48   = { payload: msg.payload.data[47]};
var x49   = { payload: msg.payload.data[48]};
var x50   = { payload: msg.payload.data[49]};
var x51   = { payload: msg.payload.data[50]};
var x52   = { payload: msg.payload.data[51]};
var x53   = { payload: msg.payload.data[52]};
var x54   = { payload: msg.payload.data[53]};
var x55   = { payload: msg.payload.data[54]};
var x56   = { payload: msg.payload.data[55]};
var x57   = { payload: msg.payload.data[56]};
var x58   = { payload: msg.payload.data[57]};
var x59   = { payload: msg.payload.data[58]};
var x60   = { payload: msg.payload.data[59]};
var x61   = { payload: msg.payload.data[60]};
var x62   = { payload: msg.payload.data[61]};
var x63   = { payload: msg.payload.data[62]};
var x64   = { payload: msg.payload.data[63]};
var x65   = { payload: msg.payload.data[64]};
var x66   = { payload: msg.payload.data[65]};
var x67   = { payload: msg.payload.data[66]};
var x68   = { payload: msg.payload.data[67]};
var x69   = { payload: msg.payload.data[68]};
var x70   = { payload: msg.payload.data[69]};
var x71   = { payload: msg.payload.data[70]};
var x72   = { payload: msg.payload.data[71]};
var x73   = { payload: msg.payload.data[72]};
var x74   = { payload: msg.payload.data[73]};
var x75   = { payload: msg.payload.data[74]};
var x76   = { payload: msg.payload.data[75]};
var x77   = { payload: msg.payload.data[76]};
var x78   = { payload: msg.payload.data[77]};
var x79   = { payload: msg.payload.data[78]};
var x80   = { payload: msg.payload.data[79]};
var x81   = { payload: msg.payload.data[80]};
var x82   = { payload: msg.payload.data[81]};
var x83   = { payload: msg.payload.data[82]};
var x84   = { payload: msg.payload.data[83]};
var x85   = { payload: msg.payload.data[84]};
var x86   = { payload: msg.payload.data[85]};
var x87   = { payload: msg.payload.data[86]};
var x88   = { payload: msg.payload.data[87]};
var x89   = { payload: msg.payload.data[88]};
x1.topic = "Tp4"; /* x.topic = " ";*/
x2.topic = "Tfumé";
x3.topic = "Tconsol";
x4.topic = "O2r";
x5.topic = "posclapO2P";
x6.topic = "posclapO2S";
x7.topic = " vitesse ventilateur";
x8.topic = "sonde1 ";
x9.topic = " temp de fumée conden";
x10.topic = " sonde retour";
x11.topic = " m/s ouverture aspi";
x12.topic = " air primaire";
x13.topic = " commande du tirage";
x14.topic = " air secondaire";
x15.topic = " reglage P chaudière";
x16.topic = " consigne fumée";
x17.topic = " regulateur O2";
x18.topic = " temp module pellets";
x19.topic = " temp O2 aspiration";
x20.topic = " A vis extraction";
x21.topic = " heures de fonctionement";
x22.topic = " reserve journaliere pellets";
x23.topic = " nbs demarage bruleur";
x24.topic = " s4 demarage bruleur";
x25.topic = " H de fonctionement maintien du feu";
x26.topic = " alimentation";
x27.topic = " regul d alimentation";
x28.topic = " consigne chaudière";
x29.topic = " sonde accu bas solaire";
x30.topic = " A vis alimentation";
x31.topic = " A ecluse a roue cellulaire";
x32.topic = " stroker";
x33.topic = " dépression du foyer";
x34.topic = " pos moteur tiroir";
x35.topic = "pos moteur grille ";
x36.topic = "regul corection alim ";
x37.topic = " commande des pompes de retour";
x38.topic = " ventil air de combustion";
x39.topic = " ventil air de combustion 2";
x40.topic = " h fonc stroker";
x41.topic = " h fonc vis alim";
x42.topic = " h fonc roue celulaire";
x43.topic = " h fonc vibreur";
x44.topic = " cycles de fonc grille basculante";
x45.topic = " h fonc WOS";
x46.topic = " h vis descendrage";
x47.topic = " h fonc allumage";
x48.topic = " h fonc sonde lambda";
x49.topic = " h fonc turbine aspi";
x50.topic = " h fonc vis extraction";
x51.topic = " cycle aeration secu";
x52.topic = " h fonc tirage";
x53.topic = " cycle fonc clapet coupe feu";
x54.topic = " deplacement du clapet tiroir";
x55.topic = " V sonde lambda";
x56.topic = " h depuis derniere maintenance";
x57.topic = " requet via ecs hk";
x58.topic = " refroidissement foyer par air secondaire";
x59.topic = " alim limiter sur maxi";
x60.topic = " augmentation P par regul foyer";
x61.topic = " pompe prélévement";
x62.topic = " V sonde lambda coriger";
x63.topic = " h fonc pellets";
x64.topic = " h en mode chauffer";
x65.topic = " sonde de la derivation superieur";
x66.topic = " sonde de la derivation inf";
x67.topic = " val consigne retour atteinte";
x68.topic = " vitesse pompe de chargement chaudiére";
x69.topic = " sonde large bande A de chauffage";
x70.topic = " sonde large bande V de chauffage";
x71.topic = " sonde large bande V rendue";
x72.topic = " sonde large bande A pompe";
x73.topic = " slb resistance interne";
x74.topic = " consigne depression";
x75.topic = " h fonc reduit";
x76.topic = "commande du tirage ";
x77.topic = " h fonc buche";
x78.topic = " WOS etat de fonc";
x79.topic = " depression reelle";
x80.topic = " A de la vis1";
x81.topic = " A de la vis2";
x82.topic = " compteur kg a reset";
x83.topic = " compteur T a reset";
x84.topic = " conso totale pellets ";
x85.topic = " rendement quotidien kw";
x86.topic = " rendement totale kw";
x87.topic = " h avant vider cendrier";
x88.topic = " gestion modbus ";
return [x1,x2,x3,x4,x5,x6,x7,x8,x9,x10,
x11,x12,x13,x14,x15,x16,x17,x18,x19,x20,
x21,x22,x23,x24,x25,x26,x27,x28,x29,x30,
x31,x32,x33,x34,x35,x36,x37,x38,x39,x40,
x41,x42,x43,x44,x45,x46,x47,x48,x49,x50,
x51,x52,x53,x54,x55,x56,x57,x58,x59,x60,
x61,x62,x63,x64,x65,x66,x67,x68,x69,x70,
x71,x72,x73,x74,x75,x76,x77,x78,x79,x80,
x81,x82,x83,x84,x85,x86,x87,x88
in the absolute I would like to log about 2500 values
Gulp!
Well, you might find it easier to put everything together in an array of objects and then use node.send() inside a loop.
https://nodered.org/docs/writing-functions
What do you do with the messages that leave the function node? Log to a file ? or perhaps display in a dashboard, or maybe build an HTML page, or send to an MQTT node?
Do you really need to send to 88 outputs rather than a sequence of messages on the one output?
If you were to declare a const array containing all the fixed topic strings then you could do the rest in a loop sending a message each time round the loop (or if you do need lots of outputs then push them to the output array then send at the end).
Thank you for your answers.
@ TotallyInformation: thanks for "node.send ()" I'm starting to search on it.
@Andrei: you have found, dashboard, log to a base influx and topic mqtt.
here is a screenshot
the 1st function: request to modbus flex getter node
msg.payload = { value: msg.payload, 'fc': 04, 'unitid': 1, 'address':0, "quantity":100}
I am a beginner, and it is not always easy to understand the answers for lack of vocabulary
@ Colin : I will also look in this direction.
Combining what @TotallyInformation and @Colin proposed you will end up with a flow like this one.
The function node would be as simple as they stated:
for (const [index, element] of msg.payload.data.entries()) {
    node.send({"payload" : element, "topic" : msg.toplist[index]})
Testing flow:
[{"id":"b25351df.63f5","type":"tab","label":"Flow 1","disabled":false,"info":""},{"id":"37aa5802.71abd8","type":"debug","z":"b25351df.63f5","name":"","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"true","targetType":"full","x":710,"y":100,"wires":[]},{"id":"1c38cd4e.87b5f3","type":"inject","z":"b25351df.63f5","name":"","topic":"","payload":"","payloadType":"date","repeat":"","crontab":"","once":false,"onceDelay":0.1,"x":100,"y":100,"wires":[["e94c1d18.09381"]]},{"id":"1a17f4a1.b2f12b","type":"change","z":"b25351df.63f5","name":"Topic List","rules":[{"t":"set","p":"toplist","pt":"msg","to":"[\"Tp4\",\"Tfumé\",\"Tconsol\",\"O2r\",\"posclapO2P\",\"posclapO2S\",\" vitesse ventilateur\",\"sonde1 \",\" temp de fumée conden\",\" sonde retour\",\" m/s ouverture aspi\",\" air primaire\",\" commande du tirage\",\" air secondaire\",\" reglage P chaudière\",\" consigne fumée\",\" regulateur O2\",\" temp module pellets\",\" temp O2 aspiration\",\" A vis extraction\",\" heures de fonctionement\",\" reserve journaliere pellets\",\" nbs demarage bruleur\",\" s4 demarage bruleur\",\" H de fonctionement maintien du feu\",\" alimentation\",\" regul d alimentation\",\" consigne chaudière\",\" sonde accu bas solaire\",\" A vis alimentation\",\" A ecluse a roue cellulaire\",\" stroker\",\" dépression du foyer\",\" pos moteur tiroir\",\"pos moteur grille \",\"regul corection alim \",\" commande des pompes de retour\",\" ventil air de combustion\",\" ventil air de combustion 2\",\" h fonc stroker\",\" h fonc vis alim\",\" h fonc roue celulaire\",\" h fonc vibreur\",\" cycles de fonc grille basculante\",\" h fonc WOS\",\" h vis descendrage\",\" h fonc allumage\",\" h fonc sonde lambda\",\" h fonc turbine aspi\",\" h fonc vis extraction\",\" cycle aeration secu\",\" h fonc tirage\",\" cycle fonc clapet coupe feu\",\" deplacement du clapet tiroir\",\" V sonde lambda\",\" h depuis derniere maintenance\",\" requet via ecs hk\",\" refroidissement foyer par air secondaire\",\" alim limiter sur maxi\",\" augmentation P par regul foyer\",\" pompe prélévement\",\" V sonde lambda coriger\",\" h fonc pellets\",\" h en mode chauffer\",\" sonde de la derivation superieur\",\" sonde de la derivation inf\",\" val consigne retour atteinte\",\" vitesse pompe de chargement chaudiére\",\" sonde large bande A de chauffage\",\" sonde large bande V de chauffage\",\" sonde large bande V rendue\",\" sonde large bande A pompe\",\" slb resistance interne\",\" consigne depression\",\" h fonc reduit\",\"commande du tirage \",\" h fonc buche\",\" WOS etat de fonc\",\" depression reelle\",\" A de la vis1\",\" A de la vis2\",\" compteur kg a reset\",\" compteur T a reset\",\" conso totale pellets \",\" rendement quotidien kw\",\" rendement totale kw\",\" h avant vider cendrier\",\" gestion modbus \"]","tot":"json"}],"action":"","property":"","from":"","to":"","reg":false,"x":420,"y":100,"wires":[["54497386.50e0ec"]]},{"id":"e94c1d18.09381","type":"function","z":"b25351df.63f5","name":"mbus","func":"const randomArray = (length, max) => \n  Array(length).fill().map(() => Math.round(Math.random() * max))\n\nmsg.payload = {};\nmsg.payload.data = randomArray(88,100);\nreturn msg;","outputs":1,"noerr":0,"x":250,"y":100,"wires":[["1a17f4a1.b2f12b"]]},{"id":"54497386.50e0ec","type":"function","z":"b25351df.63f5","name":"node.send","func":"for (const [index, element] of msg.payload.data.entries()) {\n    node.send({\"payload\" : element, \"topic\" : msg.toplist[index]})\n}\nreturn msg;","outputs":1,"noerr":0,"x":570,"y":100,"wires":[["37aa5802.71abd8"]]}]
