Function with multiple outputs
I use often function with multiple outputs;
If I need to send payload = "ON" (only one value) I write this function ....
var msg1 = {payload:"ON", topic:"light"}
but when I need to send payload = {"state":"ON"}
how I can write the msg1 ?
var msg1 = { ??? , topic:"light"}
Maybe like this?
var msg1 = {payload: msg.payload.state, topic:"light"}
var msg1 = { payload: {state:“ON“} , topic:"light"};
If you need to return a message like that, payload should be an object and not a string or a number.
You can either declare a variable and define it as an object, then assign payload that variable (option 1), or just type it in the payload (option 2).
Option 1 (using a temporary variable, then assigning it to msg.payload):
var output = {};
// some code here?
output.state = "ON";
// some more code here?
msg.topic = "light";
msg.payload = output;
Option 2 (working directly on the msg):
// some code first?
msg = { topic: "light", payload: {state: "ON"}};
If you want to use the payload directly, you can also do it like this, note that I clear the msg payload first to make sure there are no variables other than the one you need:
// some code first?
msg.payload = {}; // this will clean the existing payload
msg.payload.state = "ON"; // adds the property and assigns it the value
Using either option is a matter of personal preference. I tend to work on temporary variables, do all the operations there, and assign it to msg in the end.
It wouldn't be the first time I unadvertently modify or overwrite the payload, clearing the previous value, then try to read another value contained in it and does not work, or I get a wrong value. Working as in option 1 prevents that. But if the function is simple enough, where you only have to read a handful of values, it shouldn't be a problem.
Hope this helps.
Ok, this works for me.
Thank you very much for help :+1:
Thank you for explanation ....
You're welcome :slight_smile:
