I try to improve my code daily and today I'd like to change this code:
// 1
var bc = global.get("var_bloccocar");
if (bc == 1)
global.set("var_bloccocar", 0)
msg1 = {labelcolorcar:"#A4A4A4"}
else
msg1 = []
// 2
var bw = global.get("var_bloccowet");
if (bw == 0)
var bw2 = global.get("var_bloccowet2")
if (bw2 == 1)
global.set("var_bloccowet2", 0)
msg2 = {labelcolorwet:"#A4A4A4"}
else
msg2 = []
else
msg2 = []
return [msg1, msg2, msg3, msg4, .................];
I have a lot of this function with 8/10/14 outputs and for each I have ....
else
msg ..... = []
Is there a more "elegant" solution?
I would use null instead of [] if no msg should be sent to the corresponding output. In general I am not a friend of using function nodes in Node-Red,
E1cid
3
Without knowing what your function does i can only suggest you set all outputs to null at the start then only alter the ones that fit the conditions
const output = [null,null,null,null....etc];
// 1
let bc = global.get("var_bloccocar");
if (bc == 1)
output[0] = {labelcolorcar:"#A4A4A4"}
// 2
let bw = global.get("var_bloccowet");
let bw2 = global.get("var_bloccowet2");
if (bw == 0 && bw2 == 1)
output[1] = {labelcolorwet:"#A4A4A4"}
return output;
I think this is a very good solution; thank you!
You change VAR in LET, is there a reason?
E1cid
5
var is global scope and its better to use const and let which are block scope
I'm going to study; thank you again ....
