Not sure what I am doing wrong.
i have a value in the gauge but its showing with extra symbols in the ui
could someone please explain, it works fine if i just use a text box.
thankyou
jbudd
2
Your payload is an array (with just one element) of objects (with only one, blank key)
"" : 696.1025
How does it get in that state?
I suppose you could get msg.payload back to the value 696.1025 by passing it through two split nodes:
Or else fix the source of the data.
Colin
3
Definitely you should fix the source of the data. Having an object with an empty property name will cause you grief.
