Setting Label with {{msg.topic}}
The topic is setted by change node
This is the flow
"id": "ed4796d7.57501",
"type": "ui_gauge",
"z": "1e58ad1d.519583",
"group": "77924864.53a6a8",
"order": 0,
"width": 0,
"height": 0,
"gtype": "gage",
"title": "{{msg.topic}}",
"label": "°C ####",
"format": "{{value}}",
"min": "-10",
"max": "60",
"colors": [
"#80ffff",
"#ffff00",
"#ca3838"
"seg1": "12",
"seg2": "30",
"x": 630,
"y": 200,
"id": "15e9bf7b.946241",
"type": "json",
"pretty": false,
"x": 290,
"y": 220,
"cacd4506.dcd238"
"id": "dba09ab9.842b48",
"type": "mqtt in",
"topic": "out/dht22",
"qos": "0",
"broker": "eed163.62e4bea",
"x": 120,
"y": 220,
"15e9bf7b.946241"
"id": "cacd4506.dcd238",
"type": "change",
"name": "Temp",
"rules": [
"t": "set",
"p": "payload",
"pt": "msg",
"to": "payload.Temp",
"tot": "msg"
"t": "move",
"p": "topic",
"pt": "msg",
"to": "payload.pos",
"tot": "msg"
"action": "",
"property": "",
"from": "",
"to": "",
"reg": false,
"x": 450,
"y": 220,
"12227ba3.8a5ff4",
"ed4796d7.57501"
"id": "12227ba3.8a5ff4",
"type": "display",
"active": true,
"x": 640,
"y": 240,
"id": "15597b43.0da9a5",
"type": "go",
"name": "Test msg",
"x": 120,
"y": 320,
"9874aad3.f06688"
"id": "9874aad3.f06688",
"type": "set",
"property": "payload",
"value": "{\"Sn\":\"3389852238\",\"name\":\"TempHum\",\"pos\":\"Room 1\",\"Temp\":25,\"Hum\":\"105.90\"}",
"x": 420,
"y": 420,
"15e9bf7b.946241"
"id": "77924864.53a6a8",
"type": "ui_group",
"z": "",
"name": "Temperature",
"tab": "3dccec0c.f37104",
"order": 1,
"disp": true,
"width": "6",
"collapse": true
"id": "eed163.62e4bea",
"type": "mqtt-broker",
"z": "",
"broker": "localhost",
"port": "1883",
"clientid": "",
"usetls": false,
"compatmode": true,
"keepalive": "60",
"cleansession": true,
"willTopic": "",
"willQos": "0",
"willPayload": "",
"birthTopic": "",
"birthQos": "0",
"birthPayload": ""
"id": "3dccec0c.f37104",
"type": "ui_tab",
"z": "",
"name": "DHT22",
"icon": "dashboard",
"order": 7
(edited to add backticks by dceejay)
