There are four types (Gauge, Donut, Compass, Level) we can choose when editing a gauge node.
Is there any way to change the default appearance of level to be look like a real gas cylinder when we see in our life? Any ideas are appreciated. Thanks!!!
Not possible with the standard dashboard node.
Take a look at the svg node, or you can an create svg yourself and use the template node to render it as you like.
Thanks for the direction!!! I will try to create one svg node to do an implementation.
While not tank like - there is also the ui-level node - https://flows.nodered.org/node/node-red-contrib-ui-level/in/590bc13ff3a5f005c7d2189bbb563976
