I don't get what is happening with this dashboard/gauge.
It is a RPI
Raspberry Pi 3 Model B Rev 1.2
But the numbers going into the gauge and what the gauge is showing differ.
Sending load as separate or overall makes no difference.
Oh, and I like the -25% CPU usage.
Colin
2
Make a mini-flow with an inject, the cpu node and the gauge that shows the problem, then post that here.
what is the range you put in the node configuration?
Yet your graph shows a negative number....maybe you have to re think the range values...
btw, you do realize there are 4 cores and each can have a different value...
you also might want to display the complete msg.object....
That is true.
Coming from the cpu load node that doesn't make sense.
Alas, like so many of my problems, it seems to have gone away and is not doing it any more.
I thought one of the scree grabs showed the messages - and it is/was set to show complete message.
Anyway, as I said: It seems to have gone away.
