Generate messages with for Loops
Hi Forum,
my msg.payload has an array and i want to run a for-loop times the size of the array length. Every time the loop ends the function should return a message. Is that possible?
I tried the following but this is not working, of course
for (let i = 0 ; i<msg.payload.length; i++){
Yes it is possible, but rather than calling 'return' which exits the current function, you would use node.send(msg).
https://nodered.org/docs/user-guide/writing-functions#sending-messages-asynchronously
Thank you so much!
