Get a warning when binary_sensor is unavailable
I am working on get a warning when any one of the binary_sensors becomes unavailable.
my code is as below, my question is that I can get a warning but I am not able to show which sensors they are?
[{"id":"525511a0.bb89b","type":"tab","label":"Flow 1","disabled":false,"info":""},{"id":"8fdbcc12.5bab1","type":"server-state-changed","z":"525511a0.bb89b","name":"","server":"a569b9ca.7bfcc8","version":1,"exposeToHomeAssistant":false,"haConfig":[{"property":"name","value":""},{"property":"icon","value":""}],"entityidfilter":"^binary_sensor\\..*","entityidfiltertype":"regex","outputinitially":false,"state_type":"str","haltifstate":"unavailable","halt_if_type":"str","halt_if_compare":"is","outputs":2,"output_only_on_state_change":true,"for":"10","forType":"num","forUnits":"minutes","ignorePrevStateNull":false,"ignorePrevStateUnknown":false,"ignorePrevStateUnavailable":true,"ignoreCurrentStateUnknown":false,"ignoreCurrentStateUnavailable":false,"x":180,"y":180,"wires":[["17bb3395.53464c"],[]],"info":"^sensor\\..*battery_level"},{"id":"17bb3395.53464c","type":"api-call-service","z":"525511a0.bb89b","name":"Send push","server":"a569b9ca.7bfcc8","version":1,"debugenabled":false,"service_domain":"notify","service":"persistent_notification","entityId":"","data":"{\"message\":\"{{payload.results[0].formatted}}The garage door\",\"title\":\"binary_sensor{{msg.payload}}\"}","dataType":"json","mergecontext":"","output_location":"payload","output_location_type":"msg","mustacheAltTags":false,"x":570,"y":200,"wires":[[]]},{"id":"a569b9ca.7bfcc8","type":"server","name":"Home Assistant","legacy":false,"addon":true,"rejectUnauthorizedCerts":true,"ha_boolean":"y|yes|true|on|home|open","connectionDelay":true,"cacheJson":true}]
You might want to ask this on the home automation forum.
