Occasionally it works, but often it doesn't and this is causing all my presence detection flows to break. Can't quite work it out:
Everything else seems fine, it just seems to hate these bayesian sensors for whatever reason...has anyone else had similar issues?
Is this within a home assistant node?
Given that it sometimes works and sometimes doesn’t it would be worth opening an issue direct with the nodes author.
You can often do this on the nodes github page, there is normally a link from the nodes page on flows.nodered.org
Yep it's a home assistant node. I'll open an issue with them as well, just not sure where the error is originating from I suppose so figure it's best to flag it here as well.
