Home Assistant Entities from Node-RED missing after HA 2025.6.1 Update
since updating to Home Assistant version 2025.6.1, all Home Assistant entities (especially sensors) created via Node-RED are no longer available in Home Assistant. The connection between Node-RED and Home Assistant otherwise works as expected.
Technical details:
Home Assistant version: 2025.6.1
Node-RED add-on: 19.0.2
node-red-contrib-home-assistant-websocket: 0.77.0
Configuration: Entities are created using Home Assistant entity nodes in Node-RED
Logs: No relevant errors in Node-RED or Home Assistant logs
Troubleshooting steps taken:
Restarted both Home Assistant and Node-RED multiple times
No reinstallation of the add-on yet
Issue started: Immediately after updating Home Assistant
Request:
Assistance diagnosing the incompatibility between HA 2025.6.1 and the Node-RED websocket integration
Suggestions to restore entity availability in Home Assistant
I am happy to provide additional logs or configuration details if needed. Thank you for your support!
Hi @NeumaierC welcome to the Node-RED forum.
In case you get no (relevant) replies, I just want to let you know: the Node-RED team do not maintain (or even use?) Home Assistant or the Home Assistant Plugin so you may have better luck asking on the HA Forum if you haven't already. As far as I am aware, the majority of folk here use Node-RED without HA. That said, there are a few regulars here who do use HA so you might get lucky if one of them stubble onto your thread.
