Hi. I'm struggling with cookies. I can set and read it back with the UI template Node. But this is running in the browser. Is it possible to get the cookie in a server node for example in a function node or template node? I have try a lot things, Http request.... But i can get the cookie. Anybody know how i can do it?
Hi @jaap
can you provide some more details about what you are trying to do? You mention the UI template node - so is this to do with cookies in requests to the dashboard?
If you can access the cookies in the template node, then you could have the template node send a message back to Node-RED with the cookies in.
Or is this about HTTP requests sent to the HTTP In node? In which case you can access cookies using msg.req.cookies.
I use this in a UI template. I wil get the cookie and use it in a payload for another node
<!DOCTYPE html>
<html>
<head>
<script>
checkCookie()
function setCookie(cname,cvalue,exdays) {
const d = new Date();
d.setTime(d.getTime() + (exdays*24*60*60*1000));
let expires = "expires=" + d.toGMTString();
document.cookie = cname + "=" + cvalue + ";" + expires + ";path=/";
function getCookie(cname) {
let name = cname + "=";
let decodedCookie = decodeURIComponent(document.cookie);
let ca = decodedCookie.split(';');
for(let i = 0; i < ca.length; i++) {
let c = ca[i];
while (c.charAt(0) == ' ') {
c = c.substring(1);
if (c.indexOf(name) == 0) {
return c.substring(name.length, c.length);
return "";
function checkCookie() {
let user = getCookie("username");
if (user != "") {
document.getElementById("myText").innerHTML = ("Welkom terug " + user);
//alert("Welcome again " + user);
} else {
//user = user_input[0];
user = prompt("Wat is uw naam:","");
if (user != "" && user != null) {
setCookie("username", user, 1);
</script>
</head>
<h4> <span id="myText"></span></h4>
</html>
