You actually can send in the data, you need to set msg.satid, msg.tel1 and msg.tel2. The best way I found is to send the output of the http-in node to a split node. Send the output to the split to a switch and test msg.parts.index for a 0, 1, 2 and 3. Send each output to a change node.
In the first change node, set msg.satid to msg.payload
In the second, set msg.tel1 to msg.payload
In the third, set msg.tel2 to msg.payload
In the forth, set msg.payload to a timestamp
and send the result to the TLE node
[{"id":"f7fe6450.9276b8","type":"inject","z":"ae5ddf35.d207","name":"","topic":"","payload":"","payloadType":"date","repeat":"","crontab":"","once":false,"onceDelay":0.1,"x":140,"y":240,"wires":[["430e2c33.47bc54"]]},{"id":"430e2c33.47bc54","type":"http request","z":"ae5ddf35.d207","name":"","method":"GET","ret":"txt","paytoqs":false,"url":"https://celestrak.com/satcat/tle.php?CATNR=44109","tls":"","persist":false,"proxy":"","authType":"","x":150,"y":300,"wires":[["ea5a9d7e.d55be8"]]},{"id":"ea5a9d7e.d55be8","type":"split","z":"ae5ddf35.d207","name":"","splt":"\\n","spltType":"str","arraySplt":1,"arraySpltType":"len","stream":false,"addname":"","x":150,"y":360,"wires":[["3ad99d04.972882"]]},{"id":"3ba481d8.ac070e","type":"tle","z":"ae5ddf35.d207","satid":"M6P","tle1":"1 44109U 19018AF 20099.13260841 .00002228 00000-0 73746-4 0 9997","tle2":"2 44109 97.4708 168.0219 0060915 100.5916 315.6514 15.30648385 56824","coordsys":"latlongdeg","name":"","x":130,"y":560,"wires":[["3a2d4ef5.72f2a2"]]},{"id":"3a2d4ef5.72f2a2","type":"debug","z":"ae5ddf35.d207","name":"","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"true","targetType":"full","x":130,"y":620,"wires":[]},{"id":"3ad99d04.972882","type":"switch","z":"ae5ddf35.d207","name":"","property":"parts.index","propertyType":"msg","rules":[{"t":"eq","v":"0","vt":"num"},{"t":"eq","v":"1","vt":"num"},{"t":"eq","v":"2","vt":"num"},{"t":"else"}],"checkall":"true","repair":false,"outputs":4,"x":130,"y":420,"wires":[["a1480d7a.f1f94"],["5608bb5.0d34fc4"],["eb8bf9ca.b4a63"],["b202c21e.2e4568"]]},{"id":"a1480d7a.f1f94","type":"change","z":"ae5ddf35.d207","name":"","rules":[{"t":"set","p":"satid","pt":"msg","to":"payload","tot":"msg"}],"action":"","property":"","from":"","to":"","reg":false,"x":360,"y":360,"wires":[["2200b141.a8392e"]]},{"id":"5608bb5.0d34fc4","type":"change","z":"ae5ddf35.d207","name":"","rules":[{"t":"set","p":"tel1","pt":"msg","to":"payload","tot":"msg"}],"action":"","property":"","from":"","to":"","reg":false,"x":350,"y":400,"wires":[["2200b141.a8392e"]]},{"id":"eb8bf9ca.b4a63","type":"change","z":"ae5ddf35.d207","name":"","rules":[{"t":"set","p":"tel2","pt":"msg","to":"payload","tot":"msg"}],"action":"","property":"","from":"","to":"","reg":false,"x":350,"y":440,"wires":[["2200b141.a8392e"]]},{"id":"2200b141.a8392e","type":"join","z":"ae5ddf35.d207","name":"","mode":"auto","build":"string","property":"payload","propertyType":"msg","key":"topic","joiner":"\\n","joinerType":"str","accumulate":false,"timeout":"","count":"","reduceRight":false,"reduceExp":"","reduceInit":"","reduceInitType":"","reduceFixup":"","x":590,"y":420,"wires":[["3ba481d8.ac070e"]]},{"id":"b202c21e.2e4568","type":"change","z":"ae5ddf35.d207","name":"set timestamp","rules":[{"t":"set","p":"payload","pt":"msg","to":"","tot":"date"}],"action":"","property":"","from":"","to":"","reg":false,"x":360,"y":480,"wires":[["2200b141.a8392e"]]}]
