I would like to get the battery level of my zwave device weekly. But I couldn't find the exact command for this.
Here the JSON:
"topic":"???",
"payload": {
"nodeid":4,
"cmdclass":128
which topic I have to use? I didn't found in OpenZWave::Manager...
cmdclass "128" = COMMAND_CLASS_BATTERY
Maybe anyone got the solution for this.
thx.
just send a command like this one
"topic":"refreshValue",
"payload": {"arg":[4,128,1,0]}
with :
4 : nodeId
128 : cmdclass (COMMAND_CLASS_BATTERY)
1 : instance number (usualy good but please check the value in zwcfg_xxx.xml)
0 : index value (usualy good but please check the value in zwcfg_xxx.xmll)
don't forget that the zw controler will send the command on next device wakeup !
Qaldak
15 September 2019 18:32
3
Thanks for your input, @Francky .
But I don't receive any feedback.
the device will send the value at it's next wakeup.
This may take fews minutes, or hours, depend on it's wakeup interval... Just wait
Qaldak
19 September 2019 19:30
5
Sure, I'm still waiting.
In node-red-log, there are no failure oder any other infos. Is there another log I can check?
Add a switch and a debug node to the zwave-in node.
You should get a msg like this:
"nodeid": 4,
"notification": 3,
"help": "Notification - Node Awake",
"uuid": "xxxx"
In my case I get the message every 6 hours (Wake-up Interval = 21600).
Qaldak
20 September 2019 10:53
7
Z-Wave messages already come in (temperature, motion detection, illumination, tamper, node Awake ...).
Only the battery level is not reported. I want to trigger the battery level weekly with a Z-Wave out message. But it didn't work.
JSON (with inject node)
I also tried with a function-node - same result.
I use: RazBerry with Fibaro Motion Sensor
node-red-contrib-openzwave version?
Fibaro Motion Sensor type? (e.g. FGMS001)
Qaldak
20 September 2019 15:59
9
node-red-contrib-openzwave 1.2.4
Fibaro Motion Sensor FIBEFGMS-001-ZW5
Search in your zwcfg_xxx.xml file after <Node id="4" ... for:
<CommandClass id="128" name="COMMAND_CLASS_BATTERY" version="1" request_flags="4" innif="true">
Qaldak
20 September 2019 16:56
11
I didn't find this file.
What's the path?
Qaldak:
What's the path?
It should be in your node-red path, on a rpi .node-red
xxx = homeid
Qaldak
22 September 2019 11:58
13
There is no zwcfg_xxx.xml file, but ozwcache_xxx.xml
In ozwcache_xxx.xml is command class 128:
<CommandClass id="128" name="COMMAND_CLASS_BATTERY">
<Compatibility />
<State>
<InNif>true</InNif>
<StaticRequests>4</StaticRequests>
</State>
<Instance index="1" />
<Value type="byte" genre="user" instance="1" index="0" label="Battery Level" units="%" read_only="true" write_only="false" verify_changes="false" poll_intensity="0" min="0" max="255" value="88">
<Help>Current Battery Level</Help>
</Value>
</CommandClass>
Strange! see source 10-zwave.js:
this.on("close", function() {
log('full', 'zwave-controller: close');
// write out zwcfg_homeid.xml to disk
ozwDriver.writeConfig();
I would ask the author.
