Hello again,
i get an array of objects from node-red-contib-arp (note: filtering for mac adresses is not possible/working in that node!):
now i try to get the array index of the searched mac adress (in this case 21) and output the index and the ip address.
In the future i dont know the ip adress and the index, only the mac adress is known.
i tried:
var index = msg.payload.indexOf('1c:87:76:b0:2a:68');
msg.payload = index;
I also tied a change node:
But nothing is working as expected.
I am not familiar with change nodes / jsonata.
So at the moment for me it is a walk in the darkness.
Can someone help me?
Thanks to all in advance
If you want the full object for a specific mac you could use a function node...
var found = msg.payload.find(e => e.mac == '1c:87:76:b0:2a:68');
msg.payload = found;
If you really want the index then you could loop through the array.
To find index there is .findIndex() method
var idx = msg.payload.findIndex(e => e.mac == '1c:87:76:b0:2a:68');
msg.payload = idx;
If not found, -1 returned
If there is more than one, index of first occurrence returned.
E1cid
4
That should be payload[mac='1c:87:76:b0:2a:68']
and should return a payload object containing ip mac and iface
Thank you now it is working as expected!
