How to extract array index number?
I make an API call, the result is msg.payload : Object, which contains an array with data. I am not interested in the data itself, only in the indexnumber of the array.
For example the result is the output below, I want to extract the number 4.
{ data: array[4] }
The results differ, so one time it is { data: array[4] }, or { data: array[4=8] } (then I want to extract the 8), or { data: array[2] }, then I want to extract the 2.
Is there a simple way to do this?
Thanks,
So are you saying you are just interested in finding the total number of objects in the array that is returned - or are you looking for a specific payload/value and then want to know the index number for that ?
Craig
Only this -> So are you saying you are just interested in finding the total number of objects in the array that is returned.
To get the length of an array, in a change node
set msg. payload
to JSONata J: $count($$.payload.data)
where payload.data is the path to the array
Or in a function node
msg.payload = msg.payload.data.length;
Perfect, works, many thanks.
Thread can be closed.
