I need some help with how to convert an input received from a TCP input node to a JSON object in Node Red.
I am using Logstash, which is tailing a csv file(which gets updated every 5 minutes) and then sending it to the TCP node in a Node Red flow. Using a CSV node after the TCP input node causes it generate the output in multiple lines rather than as a single JSON object.
What should be my approach to resolve this issue?
