Get mqtt value from motion detector, if occupancy is ON or OFF
links i use
When I set my Smart Button i do like this, and it work -->
"mqtt in node"
zigbee2mqtt/Hue Dimmer - Vitus/action
When I try whit my PH motion sensor I have try whit /get but it dont work?
zigbee2mqtt/MotionSensor/get
If I try
zigbee2mqtt/MotionSensor/#
I get a list off objekt
-object
battery: 100
illuminance: 25581
illuminance_lux: 361
led_indication: null
linkquality: 52
motion_sensitivity: "high"
occupancy: false
occupancy_timeout: 0
temperature: 24.35
how do I get "occupancy: false" out as payload ?
There’s a great page in the docs (Working with messages : Node-RED) that will explain how to use the debug panel to find the right path to any data item.
BX00Cy7yHi
Im sorry. I cant get it to work.
I see the part is payload.occupancy, but I dont get where and how to put it in a node
Just send the msg into a change node like this
ahh.. Thx alot
now it work
hmm...
I dont understand why this dont work.
[{"id":"606fbab317657e8f","type":"debug","z":"fb88cea7421b6512","name":"debug 9","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"false","statusVal":"","statusType":"auto","x":840,"y":1800,"wires":[]},{"id":"b02dc8d4f8a27890","type":"mqtt in","z":"fb88cea7421b6512","name":"Bevægelsessensor Indendørs Stue","topic":"zigbee2mqtt/Bevægelsessensor Indendørs Stue/#","qos":"2","datatype":"auto-detect","broker":"711011c119463c3b","nl":false,"rap":true,"rh":0,"inputs":0,"x":180,"y":1820,"wires":[["4be81d97b9a99749"]]},{"id":"4be81d97b9a99749","type":"change","z":"fb88cea7421b6512","name":"occupancy","rules":[{"t":"set","p":"payload","pt":"msg","to":"payload.occupancy","tot":"msg"}],"action":"","property":"","from":"","to":"","reg":false,"x":450,"y":1820,"wires":[["1a6ed8fe17ba8d64"]]},{"id":"1a6ed8fe17ba8d64","type":"switch","z":"fb88cea7421b6512","name":"","property":"payload","propertyType":"msg","rules":[{"t":"eq","v":"true","vt":"str"},{"t":"eq","v":"false","vt":"str"}],"checkall":"true","repair":false,"outputs":2,"x":630,"y":1820,"wires":[["606fbab317657e8f"],["dd886caee32ab68b"]]},{"id":"dd886caee32ab68b","type":"debug","z":"fb88cea7421b6512","name":"debug 10","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"false","statusVal":"","statusType":"auto","x":840,"y":1840,"wires":[]},{"id":"711011c119463c3b","type":"mqtt-broker","name":"MQTT Broker","broker":"192.168.1.106","port":"1883","clientid":"","autoConnect":true,"usetls":false,"protocolVersion":"4","keepalive":"60","cleansession":true,"birthTopic":"","birthQos":"0","birthPayload":"","birthMsg":{},"closeTopic":"","closeQos":"0","closePayload":"","closeMsg":{},"willTopic":"","willQos":"0","willPayload":"","willMsg":{},"userProps":"","sessionExpiry":""}]
You need to add a change node and then your switch needs to look for true or false
You need to edit your switch node for Boolean true / false rather than the string "true"
Thx to @Sean-McG and @ScheepersJohan
I got it to work.
Here are the solution, I use.
[{"id":"73f8f43c36f461d3","type":"mqtt in","z":"fb88cea7421b6512","name":"Bevægelsessensor Badeværelse","topic":"zigbee2mqtt/Bevægelsessensor Badeværelse/#","qos":"2","datatype":"auto-detect","broker":"711011c119463c3b","nl":false,"rap":true,"rh":0,"inputs":0,"x":170,"y":1940,"wires":[["f2013d666b0a18d2"]]},{"id":"f2013d666b0a18d2","type":"change","z":"fb88cea7421b6512","name":"occupancy","rules":[{"t":"set","p":"payload","pt":"msg","to":"payload.occupancy","tot":"msg"}],"action":"","property":"","from":"","to":"","reg":false,"x":450,"y":1940,"wires":[["3d0918d628d76992"]]},{"id":"3d0918d628d76992","type":"switch","z":"fb88cea7421b6512","name":"","property":"payload","propertyType":"msg","rules":[{"t":"false"},{"t":"true"}],"checkall":"true","repair":false,"outputs":2,"x":650,"y":1940,"wires":[["85f542b4dcbaee10"],["57a5b288c83bfcbf"]]},{"id":"85f542b4dcbaee10","type":"debug","z":"fb88cea7421b6512","name":"false","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"payload","targetType":"msg","statusVal":"","statusType":"auto","x":790,"y":1920,"wires":[]},{"id":"57a5b288c83bfcbf","type":"debug","z":"fb88cea7421b6512","name":"true","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"payload","targetType":"msg","statusVal":"","statusType":"auto","x":790,"y":1960,"wires":[]},{"id":"711011c119463c3b","type":"mqtt-broker","name":"MQTT Broker","broker":"192.168.1.106","port":"1883","clientid":"","autoConnect":true,"usetls":false,"protocolVersion":"4","keepalive":"60","cleansession":true,"birthTopic":"","birthQos":"0","birthPayload":"","birthMsg":{},"closeTopic":"","closeQos":"0","closePayload":"","closeMsg":{},"willTopic":"","willQos":"0","willPayload":"","willMsg":{},"userProps":"","sessionExpiry":""}]
I set the occupancy time under zigbee2mqtt -->
