Get specific entities in message
Hi all,
I'm quite new to Node Red and like it already.
What I want to achieve is to send a message with the following contents;
If the train is delayed: yes/no
The departure time of the train
The departure platform of the train
I can get these entities from a sensor from the Dutch National Railroads:
As I yet don't know how to get this specific information inside a message notification I would like some help
There’s a great page in the docs (Working with messages : Node-RED) that will explain how to use the debug panel to find the right path to any data item.
BX00Cy7yHi
In the data you show above there is a msg.data.attributes.departure_delay.
You probably want to get this into msg.payload.departure_delay to pass on to a notification.
You can use a change node for that.
Thanks a lot, that will be definitely what I was looking for!
Just didn't search properly :stuck_out_tongue_winking_eye:
