I'd like a custom logger that can prepend priority flags to systemd
i.e. if console.error("fubar")
I want to output:
<3>fubar
And so on for .debug, .warn, .info ... etc.
Has this been done? thanks
I want to output:
<3>fubar
You can create your own custom logger in settings.js - see Logging : Node-RED
Have you got an example of using this that supports different handlers for different priorities or does the priority get passed in? All the examples of it I've seen seem to override a single priority.
Ok. I crafted a custom logger, set it to trace, and sure enough I get the levels for the native nodered events.
For example:
level: 60,
msg: 'Stopped node ui_switch:5e963078.ac897 (232ms)',
timestamp: 1616181045174
However, for individual function nodes that call:
console.error
or
console.warn
The log goes straight out to stdout using whatever default priority is in the service - there's no interception!
Try calling node.error etc instead
Yes - using console.log etc bypasses the Node-RED logging framework and gets written straight to stdout regardless of how you have the loggers configured.
Thanks Nick,
I'll override with a hander in global. Something like:
const _console ={
_combine : function(a) {
return Array.prototype.join.call(a);
log :function(){
console.log(this._combine(arguments));
error :function(){
console.log("<3>",this._combine(arguments));
