Getting next hours electric spot-price from Nordpool via nordpool-api-plus
I need to get hold of the "next hour" electric price from "nordpool-api-plus" node.
I've managed to setup the "nordpool-api-plus" node so I get the array of prices for the actual days spot-prices looking as this in the debug node:
array[24]
[0 … 9]
0: object
timestamp: "2023-10-18T00:00:00.000Z"
price: 46.68
currency: "SEK"
area: "SE2"
1: object
2: object
3: object
4: object
5: object
6: object
7: object
8: object
9: object
[10 … 19]
[20 … 23]
I then connect a function node after the "nordpool-api-plus" node for entering some javascript but this is where I need help;
1. How do i fetch next hours price?
Lets say I run the timestamp each hour, generating a array shown above with the actual days prices.
So at this time I want to fetch the price for object "23" in the array.
How do I do this with Javascript?
Welcome @P-solver ,
If the payload is just an array of those objects:
msg.payload[23].price will get you the price at index 23
I get an error "Function tried to send a message of type number" for this code:
var nexthourprice;
nexthourprice = msg.payload[23].price;
return nexthourprice;
Any idea what I'm doing wrong? (I'm not that good at javascript as you probably can tell :))
You’re not sending an object, in Node RED the message being passed down, needs to be an object.
return {payload: msg.payload[23].price}
Or better
msg.payload = msg.payload[23].price
return msg
So you need to determine the hour you're in then use that to find the array with that index
e.g.
const date = new Date();
///date.setHours(date.getHours()+1); // uncomment for next hour
const index = date.getHours();
msg.payload = msg.payload[index].price
your error is
You must return an object to each output.
eg. set the price to a msg property.
Try
return {topic: 'Price', payload: nexthourprice}
Worked like a charm!
Many thanks!
